23rd June 2018, 03:09 PM
Bought a rear locker last night, was stupid cheap on Facebook not even worth shimming my LSD for what this cost me
Just another Blue over Silver GQ with another TD conversion
The Following User Says Thank You to Reddave For This Useful Post:
23rd June 2018 03:09 PM
10th July 2018, 10:55 PM
Brought a front locker, got a hold of a pair of 4.3s and then swapped them for 4.6s so just need to set these lockers up in centres and get them in.
Then I can start on my motor conversion. I’m finally moving house in a couple of weeks so once I drive the car there it will all start.
Plans have slightly changed diff gear and locker wise, so I’ll be going up in tyres to compensate lol
19th July 2018, 09:38 PM
Brought a GU front diff to slot in while doing my lockers, will get it braced and rebuild the swivel hubs
21st July 2018, 05:02 PM
Stripped the GU diff this morning and dropped it off to the 4wd shed to get braced
The Following 2 Users Say Thank You to Reddave For This Useful Post:
JackoGQYoot (24th July 2018), MB (22nd July 2018)
2nd August 2018, 09:18 PM
Picked up my diff from The 4WD Shed, looking pretty
Pulled my transmission out today, engine will come out tomorrow then it’s time to try and fit the TD42.
Run into a few problems already, the motor I have is a semi electronic pump with the TCV on the pump, so trying to find a fix for that that doesn’t involve replacing the pump as I would prefer to do the pump when/if I upgrade the turbo
I have removed the EGR system and blocked the manifolds as I don’t require it
3rd August 2018, 01:13 AM
Dave are you only changing the front GQ diff housing to the GU or doing both? How do you think it will drive with different wheel widths? I know the Toyotas are a pig to drive on corrugated roads with different front to rear track widths. Also notice the brace kit is on the bottom of the housing - I just fitted mine and its on the top of the GQ diff housing - any idea why they hung your brace on the bottom side of the housing? I am going to brace my rear diff next and to keep max clearance will put it on top also.
Reddave (3rd August 2018)
3rd August 2018, 08:00 AM
#17
Peebee I will be changing the rear diff to a GU housing when I find one for the right price but there isn’t a great deal of difference between GQ and GU rear housings in width maybe 10mm
I had the brace kit put on the bottom, if it goes on the top then you really have to watch your diff to sump clearance on full bump. I’m keeping this really low so wanted as much uptravel as I could
3rd August 2018, 09:44 AM
#18
Reddave
Thanks dave, I thought it was something like 20mm per side?
3rd August 2018, 10:32 AM
#19
PeeBee
I haven’t ran a measuring tape over the two, but the 20mm a side is definitely in the front, but from what I’ve been told the rear is only 8-10mm in total width
3rd August 2018, 10:04 PM
#20
Rossco (16th August 2018)
