Results 1 to 10 of 11
Thread: Gearbox oil
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    Gearbox oil
    Hi all
    I am looking to change the gear oil on my GQ TD42.
    Which oil have you guys found works best, and how much of it will I need to do Gearbox and Transfer case?
    Td42 coily
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    for gearbox i'd go with a GL 4 grade over a GL 5, i think its 80-90.
    transfer i think is 80-90 gl5
    i'm using nulon as was the only gl4 i could get easily
  4. The Following User Says Thank You to garett For This Useful Post:
    JackoGQYoot (19th July 2018)
    Expert billyj's Avatar
    gordon
    always ran castrol vmx-m with a tube of nulon g70 in my gq, was the only oil i tried that made it shift any good
    gone to the dark side 2017 vdj 79 dc
  6. The Following 2 Users Say Thank You to billyj For This Useful Post:
    MB (20th July 2018), mudski (24th July 2018)
  7. #4
    475 Post(s)
    Blokes at our nearest Semi-Rural ‘Burson’s’ also swear by them Nulon tubes too BillyJ mate!
    They reckon its the only stuff that gets their Land Crab boxes shifting without hassle. Did buy a tube once too and might give it to a close work mates GU having highway 5th <>4th issues and see what may prove too!
  8. #5
    Oct 2017
    WA
    Just found out I will need 3.9L for the gearbox and 2.2 for the transfer. Do you guys reckon I go for the full synthetic oil from penrite or the mineral from castrol? I've been told that a 4L from Penrite will be 62$ and I will need 2 of these. It seems pretty expensive but I am leaning towards full synthetic.
    Td42 coily
  9. #6
    gordon
    im normally a penrite man but the castrol vmx-m was the only oil that got the old girl shifting any good
  10. #7
    Expert 92GQ's Avatar
    Sep 2013
    Qld
    I've been using the Pro Gear 75w-85 from penrite for years.
    What ever you choose, it must be a GL-4.
    GL-5 jams the syncros in a GQ manual transmission.
    1992 TD42 GQ Patrol Wagon
    My GQ Build Page
  11. #8
    Jul 2018
    Castrol vmx
  12. #9
    Oct 2017
    WA
    Cheers for the replies. Ended up going for Penrite GL4 as it worked out cheaper anyway.
    Td42 coily
  13. #10
    22 Post(s)
    Castrol VMX is the only oil I've used to make it cold shift properly. No need for an extra additive as it is already in the oil
    96 GQ coil/Cab
    08 G6eT
