Page 846 of 1052 FirstFirst ... 346746796836844845846847848856896946 ... LastLast
Results 8,451 to 8,460 of 10518
  1. #8451
    465 Post(s)
    What did you do to your Patrol today!
    Sent from my crapPhone using Tapatalk
  2. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Bidja (11th July 2018), Yeti's Beast (11th July 2018)
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Yeah see in the pic of my mess. The white box houses the heater core. The black box to the left houses the a/c evaporator and to the left of that is the fan motor and box.
    Yeah this is what I thought. The radiator guy that took out my heater core to check for potential leaks, which there were none (only was A/C fluid), did not remove the complete dash. They removed the glove box assy, under dash skirt, center console cover, fan housing assy, then A/C evaporator, then unbolted the heater core double ended flange pipe sections (one for for each of the heater core flow and return removable pipe). By undoing and removal of these double ended flange joint pipe sections, that cross past the core end and removed the core retaining bolts allowed the core to be slid out of the cradle to the left.
    Note: I understand that after market non genuine GUIV heater cores (others veh builds maybe the same), have the flow and return pipe welded solid into the end face of the heater core unit that prevents for easy removal as per my GUIV build.
    Glad I have not got your job there mate, looks impressive, think I would get lost in there.
  5. #8453
    Jul 2017
    37 Post(s)
    This shows the difference to mine, the GUIV has a second flange joint at the first/second bend (both pipes) to provide a clear pass.
  6. #8454
    Haha! While I have the heater box out I will replace all the foam bits too. Wish I had more time because now I want to rip the entire interior out now, lay some sound deadening down and put new carpet in. But Licola is coming up and the boss wants her garage space back.
    Now I have this apart, I really cannot see how you can remove the heater box without removing every first as some have said on Facebook. Physically impossible.
    Mate you can't pass up the opportunity to put some sound deadening in behind the dash now.
    Be stupid not to!
  7. #8455
    Jul 2017
    37 Post(s)
    Find a leak, hook up a garden hose/compressed airnow. Well done.
    Somewhere to start - These guy post all over for aftermarket stuff (Adrad systems distributor also) - Phillip Radiator Services, Phillip ACT / Ph 6282 3926. I priced genuine for mine 6mths back was around $1100+ from memory
  8. #8456
    465 Post(s)
    Radiator out. Thermostat out.
    I’ll send the rad off for a clean in and out, and a Tridon high flow stat to go in. Now back to thinking of how to go about the wiring that is under the dash. Well. Was under the dash.
    PeeBee (11th July 2018)
  10. #8457
    465 Post(s)
    Be stupid not to!
    Yeah thats what I thought but there is already some deadening there. See pic. Unless I remove the OEM stuff and put the good shit there.
  11. #8458
    193 Post(s)
    Yeah use both if you do put the ping jing on the firewall then put the factory stuff back over it.
    Sent from my SM-T800 using Tapatalk
  12. #8459
    Jul 2017
    37 Post(s)
    Propped up the patrol to check the wheel brgs adjustment - all good. Swapped out the damaged shocker - total write-off. Measured up the spring length on the brake proportional valve and its a weird setup. The free spring length is 195mm, should be in the range of 208 to 220 by the manual. Its an 'tension spring' meanings its pulling the two spring mount points together, and I can't see how i am going to get it anywhere near the ideal. Right now the lever on the arm is sitting off the actual hex head bolt that restricts movement. Any help would be appreciated. I am running an extension bracket due to the 3" nominal lift in the back, should this be removed - if I do remove it the spring will come under more load and try to shorten its length.
    Phil, check out page 48-51 of Y61 Patrol Reference document, should help out.
    http://www.nissanpatrol.com.au/ZD30-...san-Patrol.pdf
    eg: Nissan Patrol Reference Document
    Page 50 of 120
    After correction the spring is closer to a 90 degree angle (full line)
    As opposed to where it was prior to the bracket being fitted (dashed line)
  13. #8460
    195 Post(s)
    Page 50 of 120
    Many thanks for that, I will have a look at it tomorrow. Additionally I realised the actual dimension of the spring is measured with your foot on the brake - think I recall that correctly, so will get a stick of the correct length and jam it on the pedal and see what goes.
