Results 1 to 10 of 12
Thread: radiator question
    Expert jman69's Avatar
    S.A.
    radiator question
    Just wondering what are the pros and cons of an aluminium radiator for my patrol?
    Nov 2010
    Getting a life...
    38 Post(s)
    The genuine one works best. You can’t repair aluminium ones as easy. And they corrode.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
    S.A.
    will they still corrode if using ''Nissan'' brand coolant?
    Nov 2010
    Getting a life...
    38 Post(s)
    Quote Originally Posted by jman69 View Post
    That I don’t know. I guess it’s like anything. If you look after it , it will probably be fine. I just prefer the old ones.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    The GU genuine radiators were aluminum with plastic tanks not sure about anything older though
    Lucus30's 1999 GU ST TB45E
  7. The Following User Says Thank You to lucus30 For This Useful Post:
    katwoman (9th July 2018)
    Nov 2010
    Getting a life...
    38 Post(s)
    You’re probably right, but my radiators can be repaired, whereas the new aluminium ones my rad man will not touch.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
    S.A.
    Thanks for your input Katwoman. I will have to think that over untill the time comes to replace mine, won't be long it's twenty years old now. Lucus30, my patrol is a g.u. and you are right , it's just that i've heard the tanks can become brittle when theyt are old.
  10. #8
    Aug 2011
    River Heads Q
    4 Post(s)
    , it's just that i've heard the tanks can become brittle when theyt are old.[/QUOTE]
    Agree that is why I replaced original with all alloy and it really sucks the heat out. Rarely goes above 90 and usually sits on 80 degrees
  11. #9
    465 Post(s)
    Quote Originally Posted by Wizard52 View Post
    Im using a copper brass 3 core rad. Im thinking of going back to my OEM Alloy rad. Speaking with the radiator mob who gave the copper rad a clean said the Alloy radiator transfer heat better than the copper brass rads but are a fair bit weaker. So there is some compromise in using the alloy and the copper brass rad.
    Been thinking about getting a bigger alloy rad and seeing how this fairs.
  12. #10
    Jan 2023
    Good info cheers
