26th June 2018, 05:35 PM
#411
Administrator
Hey Kat how much would you want to spend?
for an extreme budget I would try and find a second hand ht18 turbo that someone is upgrading theirs.
Standard turbo for td42 and turbo manifold.
Putting an intercooler in would be ideal, you might even find a complete turbo and IC set up like this one below...
Td42 Gu turbo and intercooler kit on Gumtree http://www.gumtree.com.au/s-ad/11872...utm_source=sms
The Following User Says Thank You to AB For This Useful Post:
katwoman (26th June 2018)
26th June 2018 05:35 PM
26th June 2018, 05:38 PM
#412
Patrol Goddess
Something like that would do. No point spending big $$ on something that I won’t be allowed to keep. thx AB
What do I look at 2nd hand to make sure it’s not stuffed ?
KATROL- The 2nd
GU TD42TGi
Silent member 1208
26th June 2018, 05:44 PM
#413
Administrator
Hopefully Matty can help here but I would look for shaft play of the turbine, condition of fins on turbine making sure they don't have chips out of them and the shaft doesn't move side to side too much.
Check the inlet where the fins are to see if any scratches on wall and check if any signs of oil leakage around turbo compressor housing.
Check for cracks on IC and just general condition checks, etc.
katwoman (27th June 2018)
27th June 2018, 11:54 AM
#414
Moderator
Just ordered a 12mm UFI 250HP pump for the GUIV....
Check out my Toy -->
Rogue Dung Beetle
The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
Hodge (27th June 2018), mudski (27th June 2018), Rossco (27th June 2018)
27th June 2018, 12:48 PM
#415
MudRunnerTD (27th June 2018)
27th June 2018, 02:29 PM
#416
MudRunnerTD
Far out Dazza now you'll be smashing even more diffs with that power ...
Congrats !
I've really gotta do what you've done to my gu4 someday.
The Following User Says Thank You to Hodge For This Useful Post:
20th July 2018, 02:18 PM
#417
Moderator
Pump and front mount going on this weekend.
Just booked some Dyno time at Geelong Performance Diesel for 30th July so a week untuned will be required.
http://geelongperformancediesel.com.au/
Rogue Dung Beetle
0-TJ-0 (15th January 2019), BigRAWesty (21st July 2018), Cremulator (20th July 2018)
31st July 2018, 07:29 PM
#418
Moderator
The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
AB (31st July 2018), MB (31st July 2018), mudski (31st July 2018), Rossco (31st July 2018)
31st July 2018, 07:37 PM
#419
The Following 6 Users Say Thank You to MudRunnerTD For This Useful Post:
AB (31st July 2018), Clunk (6th August 2018), MB (31st July 2018), PeeBee (31st July 2018), Rossco (31st July 2018), Winnie (31st July 2018)
31st July 2018, 08:10 PM
#420
Moderator
AB (31st July 2018), mudski (31st July 2018), Rossco (31st July 2018)
