Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: No more gcm upgrades on new vehicles
    IMHO... as it applies to second stage manuf of 'new' vehicles... I agree with prev posts that if you already know you need a higher GVM of your 'new' vehicle when you are buying it then you did indeed buy the wrong one.
    Two of our fleet vehicles at work have second stage GVM increases, one of our 200 series and one of our Rangers.
    The 200 isn't too bad but the Ranger handles like a POS and is deadly for those who aren't aware it does NOT react anything like all the other Rangers we have.
    We now only allow people who have been checked out on it to use it.
  2. The Following User Says Thank You to the evil twin For This Useful Post:
    mudnut (14th June 2018)
    174 Post(s)
    Have a gander at the prices of the big Chevs, Fords etc. Do you think the heavier caravans on the market will loose a lot of their resale value very quickly?
    Maybe, & perhaps it might also help to convince a lot of the caravan manufacturers that there are better ways to build vans, that they can be made strong & robust without being so heavy.
  5. The Following User Says Thank You to Cuppa For This Useful Post:
  6. #23
    Jul 2015
    Camden NSW
    6 Post(s)
    This may cause some of the new 4wd small trucks ( Iveco's and others ) to become more popular for off-roading & towing.
  7. #24
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    and RAM 1500 4.5t capacity
  8. #25
    475 Post(s)
    Bob James up at ‘6x6 Australia’ has I believe legally achieved a 3.0T payload coily wagon/ute chop 6x6 GU with a 9.0T GCM. Skinnier and cheaper than Yank Tanks and also corners like a cat on carpet at 110kmph with his unique coily linked design.
  9. The Following User Says Thank You to MB For This Useful Post:
    PeeBee (16th June 2018)
  10. #26
    Apr 2013
    22 Post(s)
    where do I sign.......
  11. #27
    195 Post(s)
    Looks like a monster rear diff in the photo?
  12. #28
    475 Post(s)
    Best to give the family a call, extremely helpful team, better than I could ever explain here.
    http://6x6australia.com.au/
    Extract: 6x6 Australia’s Coil Spring Suspension with Loadshare Beams and Diff-Locating ‘A-Arms’ & Lower Control Rods (an International Registered Design) incorporates a mechanically integrated ‘Roll-Steer’ function, allowing the tyres to maneuvre under basic physical forces from the Payload as the vehicle corners (Inertia-force, Gravity, and Centrifugal-force combined). Also, in combination with our ‘Roller-drive’ Power-divider, the Coil Spring Suspension works to reduce tyre wear. It’s very subtle and difficult to describe without a proper demonstration, which helps explain these concepts further. Contact us to organize a personal demonstration for you.
