4th April 2018, 07:51 PM
TD42 injectors
Evening all, I am looking at putting new injections in. Last lot went in 200k ago 😬 and I put a turbo on 100k ago. My question is are NA and Turbo injectors the same and if I up grade to a 11mm touring pump will the injectors be different again. She’s a 97 GQ was NA now with a turbo to help tow the camper to all corners of this great land👍
4th April 2018 07:51 PM
4th April 2018, 08:01 PM
From what I know, which aint much, the injectors are the same. You can get high flow injectors, which what was put in my TD, but apparently this is not needed. I am sure the more knowledge members will set you straight...
4th April 2018, 08:10 PM
Smart like tractor
Patricapatrol
Standard injectors at standard crack pressure is all you need whether it's stock, mild or wild. A 'touring' pump is just a sales pitch
96 GQ coil/Cab
08 G6eT
4th April 2018, 09:31 PM
Thanks Ben-e-boy. Can you recommend a brand of injector? Also with regards to pump, just looking at overhauling it and people go on about the 11/12mm/touring pumps. Looking for reliability. Currently running 10psi max (according to boost gauge towing up toowoomba range @ 2600rpm in second) not in a hurry and temp gauge and egt are normal . Abit of preventative maintenance.
4th April 2018, 10:05 PM
Smart like tractor
Just re-kit the original injectors.
If it is staying a mild setup only, then a freshened up 11mm will be sufficient
96 GQ coil/Cab
08 G6eT
5th April 2018, 07:07 AM
How often should the squirters be redone / looked at on a TD ?
5th April 2018, 07:58 AM
My diesel mechanic said 100 000kms on a Td42t and 140 000kms on CRD.
He charges 700 bucks. Takes a whole day to change everything on it.
Then again I seen 360 bucks on ebay exchanged with sets done already
The Following User Says Thank You to drgtr For This Useful Post:
5th April 2018, 09:42 PM
Got 200k on mine. Am questioning if they have passed the use by date as she feels sluggish and getting black soot on the panel above tailpipe and that’s new (since 350kmark) but I am no expert . Cost wise yet to enquire
5th April 2018, 09:56 PM
Hodge
Yeah pretty much. They only need to be checked but for the cost of that vs exchange reco items then just swap them out. $3-400 every 100k is nothing.
5th April 2018, 09:58 PM
Ben-e-boy
Just to add to this. Make sure whoever does the job is using genuine zexel nozzles for the rebuild of them. A few people doing nice things with 11mm pumps these days so easy enough if you want a little more. However with your setup a nice fresh 11mm will be nice and just get the injectors set to td42t specs.
