Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Help anyone!!
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    Help anyone!!
    So I was driving to work this morning as any other morning and about a kilometre down the road the engine just die no bang no overheating battery was still fine. What I did notice was just before it died the engine light came on then it died.
    It’s cranking and all but not firing.
    I have a feeling it could be injector pump so how much am I looking at copping for that and can anyone recommend someone in metro Melbourne or surrounding east and south east suburbs for a repair.
    Regards
    Jack
    Currently own a ZD30 2000 GU patrol with a dead injector pump about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
    475 Post(s)
    Dieseltech and or Patrolapart in Lilydale are good Jack mate.
    The engine light coming prior to stopping has me baffled although worth checking there is no air in the fuel system. Have you tried pumping up the bleed hard atop of the diesel filter usually located?
    Dec 2016
    It’s rock solid
  5. The Following User Says Thank You to JackCollo For This Useful Post:
    MB (5th March 2018)
    Dec 2016
    Do you have a rough figure for replacement
    475 Post(s)
    Not sure Jack, in the thousands though. Is yours a 4.2 or 3.0?
    Others will know exacts but hopefully it’s only a minor issue, fingers crossed for you mate!
    Dec 2016
    Dec 2016
    Showing error code 73
    Pump communication line
  10. #8
    Dec 2016
    Was showing all these before but do note the maf was unplugged and the plug to the injector pump was unplugged
    Not sure why it was showing nats error
  11. #9
    Dec 2016
    Only fault showing now is 73 pump comms line
    Disconnected the battery see if that does anything
  12. #10
    583 Post(s)
    Checked the lines too mate, no holes or leaks?
