Results 1 to 5 of 5
Thread: gearbox electrical plugs
    Jan 2018
    Pt Augusta SA
    Well got the clutch sorted and now replacing the gear that I took off and had no problems but with the plugs on the gearbox. I connected all plugs bar 1 and I can't seem to find where it goes. Its near the top of the bell housing and is just a little rubber surround with a single female tab. Once I find this I can finish the work off and get to use the Patrol again. Any help would be good.
    Pete
    What car?... not an earth to the firewall is it?
    175 Post(s)
    Could not be the reverse gear trigger wire ?
    Expert the godfather's Avatar
    Mar 2011
    Piara Waters, WA
    I am betting its the reverse gear or transfer case wire as well.
    Jan 2018
    Pt Augusta SA
    oops knew something was wrong. Its a GQ Patrol and the missing connection is at the front of the box near the bell housing. I can't seem to see a connection point and haven't been able to find it in the manual which is why I ask. I'll take another look in the morning and see if I can find it.
    Pete
