Results 1 to 10 of 12
Thread: dead bushes
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    dead bushes
    just fitted a 2 to 3 inch lift (2 at the front 3 at the rear) and have a couple dead bushes, front pan-hard rod are the worst, looking at a superior engineering adjustable rod or do i just replace bushes ( i hate nolathane type bushes)
    looking at getting 2 deg caster correction bushes as well anyone know of a good quality set ?
    Most here would suggest using OE rubber bushes everytime
    Jan 2015
    19 Post(s)
    well i'm back to this again... dead radius arm bushes 2 deg castor correction. well was. drivers side is gone again. thinking about just replacing the arm, but what with?
    superior have a selection, superpro make a castor corrected arm
    are those hyper flex arms good is it worth it.
    22 Post(s)
    Quote Originally Posted by garett View Post
    Hybrid arms are about as good as you can get, for radius arms anyway. You can get the castor correction built into the arm (as you are aware) which is the pick of the bunch for a lift. (Hybrids, not drop arms)
    Adding length to the arms and getting them level or as close to (radius or rear control arms) is an improvement on a few geometries, which can be noticeable on and off road.
    96 GQ coil/Cab
    08 G6eT
    Jan 2015
    19 Post(s)
    so of these two no point going to the 1 st one? https://www.superiorengineering.com....roduct/compare
    i'm looking about trying to find whats good not rushing could take a month or two to look..
    22 Post(s)
    Which ones? There is nothing there
    96 GQ coil/Cab
    08 G6eT
  8. #7
    Jan 2015
    19 Post(s)
    oops..
    it was the hyper flex over just hybrid . only running a 2.5 inch lift
    1 https://www.superiorengineering.com....filter=251,355
    2 https://www.rv4x4.net.au/nissan-patr...gu-and-ford-ma
  9. #8
    22 Post(s)
    Personally I would go the hyperflex for what I like. But it is up to you. If you just tour around and dont do too much difficult stuff, the regular hybrids will suffice. Go the hyperflex if you like to wheel.
    96 GQ coil/Cab
    08 G6eT
  10. #9
    Jan 2015
    19 Post(s)
    thanks heaps
  11. #10
    Mar 2018
    Jimboomba
    My mechanic is about to do the bushes on the old lady... am I about to be ripped off? Should I be buying new Panhard rods instead?!
    Cheers,
    Left Lane Lady!
    #MchGillicutty’s Adventure & R & D team!
    South East Qld.
