17th January 2018, 05:36 PM
#31
themage21
Mine is a '00 GU - part of the bunch that had the crappy 5th gear from factory. It had towed camper trailers in the previous owners usage, not sure what it did in owners before then. It lasted 260k - not bad for a second rate part. But if you have to take out the gbox one way or another, I'd always vote reco, unless you know that the replacement box is from outside of the affected year range.
Additives aren't going to help, because it's not a heat/wear thing, the splines actually tear and round over from mechanical overload/fatigue. I've got my old layshaft and gear and you can see where the shoddy gear never engaged with the end of the spline. Outside of that, the shaft and gears all look like they're brand new, because of regular oil changes.
It would be great if you can post a picture of that here.
What is time period the bad 5th gear was installed into the GU gearbox?
17th January 2018 05:36 PM
17th January 2018, 05:39 PM
#32
sooty_10
I believe it was a problem up till some stage on '02. From all my reading you are safe of the box is from an '03 or up. Mine was an '01.
Does that include the GQs RB30 & TB42 boxes as well?!!
17th January 2018, 06:02 PM
#33
I am he, fear me
dom14
No... as prev posted... TD42 only from 99 to 02
Pic of the old v new 5th gear with the extended spline
http://grantm.customer.netspace.net.au/5th4.jpg
dom14 (18th January 2018)
17th January 2018, 06:29 PM
#34
dom14
There is good pics floating around showing the changes. Potentially on the other patrol site. I will endeavour to get some pics if I get my old gearbox back from the mechanic.
The problem boxes I believe were early TD42t/ZD30 GU's up till some stage in '02.
The Following User Says Thank You to sooty_10 For This Useful Post:
17th January 2018, 06:32 PM
#35
the evil twin
Didnt see this before my previous response.
Yep thats one of the good pics I mentioned. They have also increased the length of the spline on the main shaft. Massive overall increase in contact surface area between the shaft and gear.
9th February 2018, 08:18 PM
#36
So i ended up getting a 2nd hand 3L crd gearbox from patrol-a-part. Only had 77k kms I believe. All in and installed and I am back on the road.
mudski (9th February 2018)
9th February 2018, 08:28 PM
#37
Breadmaker Shaker
sooty_10
Thats good mate. Ive got an 01 GU TD42 and waiting for this to happen. Every time uphill in 5th it crosses my mind.
Actually a mate of mine not on this forum did his 5th years ago and fought Nissan about it. Got labour free I think but not parts.
![](image.php?u=115&type=sigpic&dateline=1651651487)
9th February 2018, 08:32 PM
#38
Plasnart
The good news is if 5th does go, you can always use 4th to get home.
All up cost me $880 + freight for the box, and $650 in labour. No way was I going to do it at home when thats all the labour costs, gearbox out is a prick.
9th February 2018, 08:43 PM
#39
Breadmaker Shaker
sooty_10
Dont blame ya. $650 is easily worth the labour. Have you checked your fire wall? Has it been panel beated like I've heard happens to make the job easier? Hopefully they tilted the engine and did it nicely.
9th February 2018, 08:45 PM
#40
I'll check mate. Good advise. I had to remove the engine mounts and drop the engine onto the chassis mounts to do it myself last time I had it out.
