Results 1 to 10 of 10
Thread: ZD30 ... Low boost
    Expert Limmy's Avatar
    ZD30 ... Low boost
    Hi members
    Need some advice !
    Nissan 2005 GUIV zd30
    l have dawes set up , needle valve, egr . etc. My patrol has been running fine last few years. Last week i realised my Boost was lower than usual . I though it was probably need adjustment. I stretched the spring and it was set fine back to normal. A few days later , Im struggling to get over 10Psi , with crap fuel economy. I tried to stretch the spring again. Didn't work , I also ordered some more heavy duty springs, still couldnt get past 10psi.. I tried another Dawes valve, still struggling to reach 10psi. I played around with the needle valve, the actuator level moved .
    I'm thinking maybe the wet weather had something to do with it. I couldnt find any obvious boost leaks .
    Any ideas guys ?
    TIA
    Limmy
    Oct 2017
    ZD30 ... Low boost
    Egr stuck open? Unless it’s blocked that is.
    Otherwise check all turbo and intercooler pipework for loose hose clamps, boost gauge lines, intercooler etc for leaks
  4. The Following User Says Thank You to trev zd30 For This Useful Post:
    Limmy (6th December 2017)
    EGR blocked. Can I do the soapy water trick to test the lines and pipes. Will it still have boost pressure while it idling so I can test ?
    What intercooler do you have, if its the OE one chances are its leaking.
    easy to check if its oily its leaking
  8. #5
    I got a welded intercooler. I did notice a bit of oil around my boost sensor on the intercooler. I got one of those boost gauge adapter's that sandwich between intercooler and boost sensor. Maybe that leaking . I might silicone it
  9. #6
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Sounds like it could be a vacuum problem to me. Soapy water won't show a vacuum leak. Usually the hoses split in the most difficult to see spot. You will have to check the hoses one at a time.
  10. The Following User Says Thank You to BillsGU For This Useful Post:
  11. #7
    ^^^^^This...
    Quote Originally Posted by Limmy View Post
    ....and this.
    Boost leak 100%.
    And no need to stretch the spring in the dawes anymore. This issue was corrected with a stronger spring about 3 years ago. Unless you have one of the older Dawes with the old spring then disregard my comment.
  12. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Limmy (6th December 2017), threedogs (6th December 2017)
  13. #8
    i had the older one. ive put on another one ( smaller one with ceramic ball ).. Where would the vacumm hoses be located ? Im going to buy new silicone hoses tomorrow. clean my intercooler.
  14. #9
    Jul 2010
    Thurgoona
    7 Post(s)
    Start at the hose connected to the turbo actuator and work back to the vacuum pump located on the front of the engine. Also - there are vacuum hoses connected to solenoids under the intercooler. That was where mine were split.
  15. The Following User Says Thank You to BillsGU For This Useful Post:
  16. #10
    I think i may have found the problem. While i was replacing all the lines with new silcone ones. i was removing old line from the " boost gauge inline filter " i notice it had a crack and split apart a bit when i pull it. It has some black soot in between the joins. I blew air and it definately is leaking.
    Hope that is the main problem ! im ordering another filter
    keep you posted !
  17. The Following 4 Users Say Thank You to Limmy For This Useful Post:
    AB (6th December 2017), Flippa74 (13th December 2017), mudski (6th December 2017), threedogs (7th December 2017)
