Results 21 to 30 of 45
Thread: Timing cover and backing plate removal
  1. #21
    PM me your deets mate. I'll send you the two orings for the timing plate.
  2. The Following 2 Users Say Thank You to mudski For This Useful Post:
    dom14 (22nd November 2017), Winnie (23rd November 2017)
    Thanks mate, I didn't even think about you for parts! But I have this kit on order.
    http://patrolapart.com.au/product/ge...er-gasket-set1
  5. #23
    yeah that kit has got everything you need. looks the goods.
  6. #24
    Seriously struggling to remove the crank pulley. Can't get the tapered cone to release.
  7. #25
    Had a major win today and with help from a bigger hammer, got the crank pulley off.
    Pulled the timing gears and backing plate off and it was very obvious where the leak was coming from so this hasn't all been a waste of time.
    Now it's time to start cleaning the surfaces ready to be put back together.
    Tore the bloody sump gasket though when I was pulling off the timing cover so will have to change that out too now.
  8. The Following User Says Thank You to Winnie For This Useful Post:
    dom14 (29th November 2017)
  9. #26
    22 Post(s)
    What's the rubber on the back of the balancer look like?
    96 GQ coil/Cab
    08 G6eT
  10. #27
    Visually it looks fine. I've had 2 mates who are mechanics look at it and say there's nothing wrong with it but didn't do anything other than look at it.
  11. #28
    Legendary dom14's Avatar
    38 Post(s)
    I guess you can give it a clean with WD40 and a wire brush and see if there are any cracks, but if a mechanic says it's ok, then it must be ok.
    Pretty interesting to see the not so simple timing gear inside a TD42.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  12. #29
    38 Post(s)
    Is this a turbo TD42 or an NA one?
    Cheetah Outreach
  13. #30
    It's an NA engine with after market turbo.
  14. The Following User Says Thank You to Winnie For This Useful Post:
    dom14 (30th November 2017)
