Results 1 to 9 of 9
Thread: Hi there everyone
    Nov 2017
    Hi there everyone
    Hi there everyone, Just starting out and looking at buying a Nissan Patrol. I am looking at a 3.0 turbo diesel have heard some great reports on these vehicles, but was just told recently that they do tend to overheat causing blown turbos and melted piston rings. Is this just a load of BS or does this occasionally happen, as I was quite keen on the Patrol and thought if anyone would know it would be the people that already own one. Any helpful information would be greatly appreciated. Cheers Shane.
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    a lot of miss information was spread about the ZD30
    in the patrol, they sometimes over fueled and then you had problems - mainly (my opinion) from bad ECU mapping
    same motor (with different air intake design & different ECU map) is in the Navara........... no bangs or "grenades"
    anyone and everyone has an opinion about the 3L
    the first 2 series were bad - but things were fixed by the time series III came out
    some teething problems with the CRD3.0L - but were eventually fixed
    same 3.0L D4D in Playdoh and Hilux
    hilux under powered compared to Playdoh
    playdoh has injector and starter problems Hilux dont have
    the ZD30 and the CRD30 are both good motors, different things in the NADs need to be done, but they are an honest and reliable motor if you dont thrash them
    BTW
    welcome to the forum
    do a search on NADs, lots of information there for you about the 3.0L
  4. The Following User Says Thank You to Bigcol For This Useful Post:
    GQtdauto (9th November 2017)
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    G'day and welcome mate. I can only offer that I have a series 4 ZD30, 245000k and no issues. Yes all cars have some problems IMO, but the stories outnumber the truth. I have NADS as @Bigcol mentioned. More common I think on all models is leaks from the intercooler. When it leaks, replace it with a welded intercooler, either like for like or upgrade to larger one, depends on your wallet. Notice I said "when" it leaks.
    Cheers Tony.
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Welcome mate , our 2002 model is still going , big exhaust no chip and over 300thou on the clock .
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate
    Nov 2017
    Hi there everyone and thanks to the fast response. I don't mean to sound stupid here but can someone please explain as to what NADs mean, I am kinda new to this. Cheers Shane.
  9. #7
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Quote Originally Posted by shanepk38 View Post
    Nads = Nissan anti detonation system? , I think @mudski is the guru on the subject , if you search the forum using nads as the keyword you will find more info on the subject .
    From what I understand it's a few modifications to the engine and ancillary components to reduce the chance of motor failure.
  10. #8
    581 Post(s)
    Welcome to the forum mate!
  11. #9
    Feb 2011
    Shed
    45 Post(s)
    G'day Shane welcome to the forum mate
