Results 11 to 20 of 23
Thread: Does this look like a gasket leak or much worse
    Expert billyj's Avatar
    gordon
    3 Post(s)
    tb or td? definetly looks like a front crank seal, if its a tb there about a $20 part and 15 min job to change
    gone to the dark side 2017 vdj 79 dc
    Oct 2017
    its a tb. thanks.
  4. #13
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by billyj View Post
    It's lot cheaper in RB30 but takes lot longer. Fan+shroud, timing belt cover(s), three belts, harmonic balancer, crank gear, etc etc.
    All those takes a fair bit of time. I am beginning to believe things are lot easier with push rod engines.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  5. #14
    Beginner PatrolLord's Avatar
    Feb 2016
    Tipperary - Ireland
    Quote Originally Posted by mpisano View Post
    so in saying all this, how safe is it to be driving the car around? should i get it to mechanic ASAP, or will i be ok to drive around for a few hundred kms keeping an eye on the oil level and making sure it has oil in it.
    You can drive it as long as you like if you can top up the oil faster than it loses from the shagged seal.
    I'm not rude. I just hate bullshitters
    Nissan Patrol 3.0 CRD 2" lift
    33" mud terrain tyres
    Roof rack and custom snorkel
  6. #15
    Oct 2017
    i have had a quote to get the crank seal done from $140 - $170, so I will just do it.
  7. #16
    80 Post(s)
    Deleted post, 'cause I gotta get better glasses!
  8. #17
    gordon
    3 Post(s)
    If you find that the shaft has a deep groove worn into it, there are shaft repair sleeves available.
    seal runs on the back of the balancer not the actual crank in a tb
  9. The Following 2 Users Say Thank You to billyj For This Useful Post:
    dom14 (27th October 2017), mudnut (27th October 2017)
  10. #18
    38 Post(s)
    Deleted post.
    Craig, it may be time we both switch to a TB42.
    Cheetah Outreach
  11. #19
    80 Post(s)
    I will go for a TB45 or TB48 when the RB gives up the ghost.
  12. #20
    Jun 2017
    After major servicing and having to take my car back to the mechanic as it was still leaking, i have found another oil leak. If i could find it and i know nothing about cars how could they miss it? $5500 later and i want to avoid taking it back there, can someone help me out with this leak.
    It looks to me like a gasket/seal? am i right or does it look like alot worse and going to cost me alot more money to fix.
    its the sump behind the bash plate.
    Don't worry oil is cheap
