Page 200 of 220 FirstFirst ... 100150190198199200201202210 ... LastLast
Results 1,991 to 2,000 of 2192
Thread: AB's new GQ is finally here
  1. #1991
    49 Post(s)
    Come on @AB go do the same, we need to know.
    it's AB's showertime
  4. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    jay see (7th October 2017), MB (7th October 2017)
  5. #1993
    583 Post(s)
    Around 90-100mm
    Not the most accurate way of measuring but should be close enough to work it out.
    Sorry about the delay, was a long shower... Exactly the same as your pic Winnie.
  6. The Following User Says Thank You to AB For This Useful Post:
    Winnie (8th October 2017)
  7. #1994
    583 Post(s)
    Feels a lot different to drive now with the GU diffs that's for sure, feels a bit heavier.
    Turning circle might be a bit less too, need to confirm that with more driving, would they have to put stops in with this mod?
  8. #1995
    The stops should be all there mate just like on the gq items. It will feel different due to geometry being different between gq and gu diffs. The heaviness you feel is a slower turn in but once turned will fee better. Apart from the width there is quite a bit of difference in king pin inclination
  9. The Following User Says Thank You to nissannewby For This Useful Post:
    AB (10th October 2017)
  10. #1996
    583 Post(s)
    Thanks Matty, wasn't sure if it was the old placebo effect with geometry but it just felt like the car was wider and steering was all new. I know it's only 20mm each side but a whole new game to get used to.
  11. #1997
    193 Post(s)
    What about steering box is that a GU one now? Might change steering feel too. I know after getting my new steering box felt different first time i drive it for some reason. It's still a GQ one but felt like more turns lock to lock? . .
  12. #1998
    583 Post(s)
    Yep GU box as well.
  13. #1999
    193 Post(s)
    Now you just need a GU body swap and she'll be just about done!
    She's nearly turning into as much of a mongrel as mine . . .
  14. The Following User Says Thank You to Rossco For This Useful Post:
    Plasnart (11th October 2017)
  15. #2000
    583 Post(s)
    Might have to create wanker name for mine lol
  16. The Following User Says Thank You to AB For This Useful Post:
    Rossco (12th October 2017)
