Results 21 to 30 of 35
Thread: Which brake pads?
    Apr 2013
    Mount Nasura
    Yeah, went with the same setup as the link I posted.
    So far the braking is great but been towing a lot so not 100% tested yet
    Braided lines will be next I reckon as the pedal is still very soft
    Nisshead, is this the set up you went with, how do you find it?
    http://www.ebay.com.au/itm/DRILLED-S...372&rmvSB=true
    Thinking of fitting it as well but a bit suss on the rotors as they have no brand on them. Price looks good though. If I go DBA with Bendix pads looking at just over $150 a corner!
    2008 GU ST Bog stock and no smoking barrels!
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by Beni C View Post
    Yep, same setup.
    So far so good, pulls up a lot better then before.
    I will eventually get braided lines as well but so far so good
    ________________________
    ______ 2017 D-Max _______
  4. #23
    465 Post(s)
    Yep, same setup.
    When i added the braided lines to my troll it was amazing the difference i felt. Now im used to it. But i will be up for new front pads and rotors in the coming months when i get around to fitting up the TB calipers. Im using Bendix 4wd pads and they are ok but i have found they overheat fast. The drilled and slotted RDA rotors i have are ok i guess. I might have to do some more research.
    Maxhead (14th October 2015)
  6. #24
    Apr 2013
    Mount Nasura
    Yep, same setup.
    Was there any indication on what brand the rotors are mate?
  7. #25
    ACT
    Not that I know off mate. I gave them to my mechanic mate to fit.
    If there were any issues he would definitely let me know.
    All good so far
  8. #26
    Jun 2016
    melbounre
    Hi has anyone know the best place to purchase new brake rotors for the gq in melbounre
  9. #27
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Which brake pads?
    I use online "spare box auto parts" to order my Bendix brake pads, good price and quick delivery -
    Edit: Just realised your were after rotors, pretty sure they sell them as well though
  10. #28
    49 Post(s)
    Thread dig....
    I'm up for new pads. I've managed about 50,000 km out of a set of Bendix HD. The fronts need changing and the rears have a little left. I'm going to buy a full set and do the rears when needed.
    50k is that good??
    Have never really kept track of them in the past.
  11. #29
    Thread dig....
    50k is that good??
    Nothing but Bendix extreme 4wd pads. It's a big car and they pull up. Worth the money. Buy from repco using you racv card for a discount.
    Super cheap should have a big sale for Bathurst weekend too.
    Function over longevity for me. I'm sure you could get some that give you 100k but they won't stop like Bendix.
    jay see (6th October 2017)
  13. #30
    49 Post(s)
    Yeah, been happy with the ones I put in some 2 1/2 years ago.
    Know someone at autobarn so might be able to get them cheap.
    What are people getting out of a set of pads??
