29th September 2017, 08:18 PM
#31
Would the neutral safety switch be the issue? I've gone from Tb42e auto to td42 manual using the Tb42e auto loom...
29th September 2017 08:18 PM
29th September 2017, 08:55 PM
#32
BrodieTiGQ
Got reds but no radio or anything ?
What's reds? Have you checked all the fusable links are hooked up & all good, Ignition switch is hooked up right.? Not sure about auto neutral cut out. . Possibly, need someone but more learned than me with electrics but wouldn't stop the accessories from working tho. . .
29th September 2017, 09:02 PM
#33
Can you send a picture of your wiring? And engine bay?
29th September 2017, 09:03 PM
#34
Fusable links..? What's a fusable link?
29th September 2017, 09:04 PM
#35
Where's the ignition switch? Cause i thought that too.. cause the starters not even cranking..
29th September 2017, 09:50 PM
#36
Fusable links come straight off the battery and go to certain parts of the loom. Theres one that goes to the igniting switch (key barrel), sounds like that one might not be hooked up maybe. They're the ones on the left of the battery with white & black plugs.![](http://www.nissanpatrol.com.au/forums/images/imported/2017/09/187.jpg)
29th September 2017, 10:01 PM
#37
I don't have plugs like on mine?
29th September 2017, 10:22 PM
#38
They all sit in a black plastic bracket type thing on the GQs. Kinda hard to see it in pic but next to orange winch wiring. Yours should have something similar . .
29th September 2017, 10:30 PM
#39
Yeh it did I took them all out , but I don't have them wires in the picture? Could you get a closer picture tomorrow?
30th September 2017, 09:55 AM
#40
