Page 795 of 1054 FirstFirst ... 295695745785793794795796797805845895 ... LastLast
Results 7,941 to 7,950 of 10532
  1. #7941
    80 Post(s)
    Finally got the right 4gl gearbox oil and now the gearshift is so smooth. Although a lot quieter the harsh whining noise is still there in the cluster (1st, 2nd 3rd and 5th). 4th is almost silent so I'm just gunna turn up the radio and pretend all is good.
  2. The Following User Says Thank You to mudnut For This Useful Post:
    Touses (13th September 2017)
    43 Post(s)
    Tested out the air tank , was able to get from 15psi to 25psi in about 15 seconds and that's with a chunky 33" muddie so thinking a double tank setup could be the go .
    Awesome..
    I think my thumper will appreciate a tank..
    I have a 5kg tank at home actually lol..
    I'll clean it up and oil the inside with fish oil..
    Think I'll mount it outside the cabbin though
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    GQtdauto (13th September 2017)
  6. #7943
    80 Post(s)
    @bigguwesty Fish oil eventually dries out (may flake off) and also goes milky when subjected to moisture.
  7. #7944
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Awesome..
    If yours is the double thumper like mine it's rusting the fittings so must be a lot of condensation in there somewhere , must put something in the tank to rust proof it myself .
    Pumped up the trailer tyre today and from 20 to 38 psi in about the same 15 secs .
  8. #7945
    195 Post(s)
    Condensation is simply from the air compressing and cooling. You wont exclude it, but to get rid of it you need to vent it to atmosphere, which unfortunately means you lose the pressure. To maintain the pressure without the moisture, you need a drier, but not practical. @MB suffered from this on a recent trip where the moisture froze and disabled the difflocks. If you want everything to be 'rust free' go stainless or aluminium.
  9. #7946
    Jul 2013
    3 Post(s)
    Filled up the wind screen washer bottle.
  10. #7947
    193 Post(s)
    Quote Originally Posted by Bush Ranger View Post
    Far out . . . Any pics?
  11. The Following User Says Thank You to Rossco For This Useful Post:
    MudRunnerTD (24th September 2017)
  12. #7948
    175 Post(s)
    Did you disconnect your battery for 30 minutes to clear out any fault codes after ?
  13. The Following User Says Thank You to Hodge For This Useful Post:
  14. #7949
    583 Post(s)
    Just got a knock on the door from a stressed delivery driver bogged hard on the most shittiest driveway in Australia next road over. Man I love my Gq, what a beast!!! Apparently RACV turned up and couldn't do anything and wanted this poor bloke to get a crane in $$$
  15. The Following 3 Users Say Thank You to AB For This Useful Post:
    GQtdauto (14th September 2017), MudRunnerTD (24th September 2017), Rossco (14th September 2017)
  16. #7950
    193 Post(s)
    Yeah nice, what road was it on? He was pretty lucky he certainly knocked on the right door . . .
