Page 793 of 1056 FirstFirst ... 293693743783791792793794795803843893 ... LastLast
Results 7,921 to 7,930 of 10551
  1. #7921
    475 Post(s)
    Pics please Phil!
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Finally finished the winch install.
    Wired up an in cab controller with isolator switch to the centre console.
  4. The Following 2 Users Say Thank You to Mc4by For This Useful Post:
    MB (10th September 2017), Rossco (10th September 2017)
  5. #7923
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Tested the flex out over some rocks out Eldorado, scored a fire extinguisher that will make a great air tank , some wanker has dumped about 20 of them in the Park .
  6. The Following User Says Thank You to GQtdauto For This Useful Post:
  7. #7924
    475 Post(s)
    Good work mate, pics pretty please & recycling at its best :-)!
    Arseholes, some dumping pricks hey :-(
    Extinguishers please do be careful though as a lot of gear us blokes buy can run high. ARB twin pumps for example are set @150psi ish and many blokes are running air tools too :-)
    GQtdauto (10th September 2017)
  9. #7925
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Mine runs to 150 as well , extinguisher is rated to handle over 400 psi and normal operating pressure is 190 so as long as I get the cap right it should all be good .
  10. The Following User Says Thank You to GQtdauto For This Useful Post:
  11. #7926
    475 Post(s)
    Gold then mate :-)! I've got quite a few given to me from CFA retired changeovers etc.. Generally use em as fertiliser pressure packs around the block at low PSI. Should we worry about rust in these old tanks? Mind me there is quite the tolerance down to 150psi from 400psi spec you kindly educate me ;-)
  12. The Following 2 Users Say Thank You to MB For This Useful Post:
    GQtdauto (10th September 2017), Maxhead (10th September 2017)
  13. #7927
    Dec 2016
    Northeast Victoria
    41 Post(s)
    I'll post some pics of the extinguisher tomorrow and the pressure limits and testing figures , I've got to go back out for some wood and I now have to grab another three , son wants two and I'm going to try for a two tank setup.
    Extinguisher is roughly 150mm diameter by 350mm high .
  14. The Following User Says Thank You to GQtdauto For This Useful Post:
  15. #7928
    196 Post(s)
    @Mc4by, how do you keep that interior clean - never seen a white trim before - is that leather or fabric? Sorry, 1997 GQ perspective coming thru!!
  16. #7929
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Is it possible to go off road and not get some in unless you're a bitumen bunny .
  17. #7930
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Fabric trim.
    Fantasy answer: I make the wife take off all her clothes before she gets back in the vehicle
    Reality: Canvas seat covers.
  18. The Following User Says Thank You to Mc4by For This Useful Post:
    PeeBee (11th September 2017)
