4th September 2017, 02:56 PM
Bob
Can someone help out an old bloke and tell me what a Portal Upgrade is ???
So you can quickly drive your car into the next dimension of space & time
Winnie (4th September 2017)
4th September 2017 02:56 PM
4th September 2017, 03:09 PM
Apart from being able to say "I have portals" what else necessitates the upgrade? Although it might be able to be engineered you will easily be picked for the height of the vehicle.
Other things like how much more do they weigh over conventional axles? Is it gonna leave much for your gvm?
It will lose handling any shift and cog will cause that.
Then their is also the fact that they are worth as much if not more than the car. Sell it and get an iveco daily if you want height, ability to run 37" tyres, 100:1 through the transfer plus a gvm much more than your patrol.
Don't get upset about this stuff I try to think about these things logically.
GQtdauto (4th September 2017), MudRunnerTD (4th September 2017)
4th September 2017, 03:48 PM
Rossco
Ha Ha The Dimension that I am in at present is enough for me LMAO
The Following User Says Thank You to Bob For This Useful Post:
Rossco (4th September 2017)
4th September 2017, 03:55 PM
nissannewby
They look good, though, Matt. http://www.marks4wd.com/patrol-portal-axles.html
4th September 2017, 04:29 PM
nissannewby
All fair points. I like my Patrol and look at this upgrade , if practical and cost effective as just another enhancement. It doesn't ride or drive like a truck, which I suspect the Iveco would. I don't drive like a crazy fool, so am a bit unsure how it will lose handling, especially with a footprint circa 6-12" wider than it currently is. I don't do 'stuff' to gain attention, if it improves the performance and I am happy with it, then I do it. Running 35" tyres is a clearance issue and becoming more of a passive necessity as more people are running around on them and making the centre of the track higher. Ending up with the ability to tonk on thru ugly rutted up sections without breaking anything is good enough reason to pursue this investigation.
Forgot, GVM upgrade is part of the kit, so vehicle GVM goes up to circa 3900kg's, so this is no doubt part of the diff housing and suspension upgrade that takes place.
Cost is not really a factor as my patrol is my hobby, couldn't care less what I spend on it as long as i am happy to spend it. Right now market value of the vehicle is 6K, but its insured for a hell of a lot more than that. Choices don't simply have to be 100% against what the end result is - I suspect that 99% of vehicles on the road are not worth what the owner paid for them or have invested in them.
Bit unsure about the height remark except perhaps road rules in WA and maybe others having max vehicle height restriction - if thats the case will simply have to cross that bridge if it arises. This mod, will be VASS engineered and compliant in Victoria.
If you have any information of a negative nature regards the conversion i am happy to hear it, but I would ask that it not be subjective, must be fact based and demonstrable or something I can check myself. Thanks for the note.
4th September 2017, 06:07 PM
The height remark was pointed at it going to 7 inches taller than it is now. (6" from portals, 1" going to 35s from 33s.). I had a lifted gq back in my younger less knowlegable days with 5" suspension lift, 2" body lift and 35s. It was only a toy for more hardcore focused drives and even being young it got tiring getting up into. Its a long way up lol.
4th September 2017, 07:08 PM
#17
The 747
Is your idea here Phil to be able to run smaller tyres (to fit in the garage) and maintain ground clearance?
4th September 2017, 07:44 PM
#18
Administrator
Winnie
I think he's selling the house so he can fit the platinum pony in the new one?
Platinum pony = Phil
Golden horse = mb
Bronze bunny = Rossco
The Following 2 Users Say Thank You to AB For This Useful Post:
Bacho86 (5th September 2017), Rossco (4th September 2017)
4th September 2017, 07:50 PM
#19
nissannewby
Right, I had not even thought about access issues to be honest. Good point, made it onto 'the list', thanks
4th September 2017, 07:51 PM
#20
AB
Golden horse = mb
Yes, once we extract the daughter, boyfriend and dog, we are downsizing the house and expanding the garage! Looking to go bush as well.
