Page 1051 of 1454 FirstFirst ... 515519511001104110491050105110521053106111011151 ... LastLast
Results 10,501 to 10,510 of 14534
  1. #10501
    465 Post(s)
    👆🏼that sucks balls
    Yes it does. Using a loader to pick up the wood all the small stuff is naturally on the bottom. Next time I will ask them to pick the first load up and then dump it on top, and then pick up from the bottom again.
    465 Post(s)
    I can confirm the ALDI drill mounted pump doesn't like thicker fluids.
    It struggles. And the shaft going into the drill is perfectly round and stainless so add a bit of oil and you've got no traction.
    Unless you like friction welding .
    MBs idea worked 300ml at a time ...
    I use a long length of hose for the gear box, running up from the filler and into the engine bay, then with a funnel jammed in the hose. Then I just pour in until it over flows.
  4. #10503
    195 Post(s)
    I bought a large plastic syringe what holds about 150ml and has a large dia outlet, maybe 4mm dia. I have used this on occasion to fill that last level point without having the fluid overflowing or ending up with the messy volume in the transfer hose. It works best when the oil is warmish, but when its thick and cold the effort to empty is significant especially in awkward spots. Its worth hunting down one of these I reckon as you can fill an entire gearbox with it, takes a while, but its very small, perhaps 30mm dia and 150mm long, and dead robust simple. It works with any fluid and just needs a simple flush out to reduce cross contamination.
    mudski (24th August 2017)
  6. #10504
    I get a load of Redgum from the local garden supplies and probably 70% of it is tiny pieces. I will burn through this like no tomorrow. Atleast I dont need to split any I suppose.
    Attachment 72968
    Buying wood from any gardening supplies = wood chips. :]
  7. #10505
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Most of the suppliers around here prey on the fact that almost nobody knows how crappy the wood they sell is , I've refused loads in the past , son dropped me off a half trailer load of red box that was well seasoned probably over 12 years dead but still attached to the tree so was a massive branch .
    I'm still burning it after nearly two weeks and next week I'm going to go looking for some more of this incredible stuff .
  8. #10506
    465 Post(s)
    Last two lots weren't. They were nice big pieces that I had to actually split to fit in my fire place.
  9. #10507
    Ask 'em for a refund, or exchange.
  10. #10508
    465 Post(s)
    Lol that means loading all back up in my trailer. I just have to make sure the next load isn't like this before they dump it in my trailer.
    mudnut (24th August 2017)
  12. #10509
    22 Post(s)
    Half way through doing transfer and front diff oils ... Heavens open up ! Ok ... My fault for not checking radar.
    Then my tom thumb pump breaks ... Great! Front diff I have room to tip 1L bottle up but transfer case I'm buggered . Oh well.
    . Called it a day.
    I always fill an old esky or bucket with hot water and put thegear oil drum in it and leave it in the sun untill I need it.
    It makes it much easier to pump
    96 GQ coil/Cab
    08 G6eT
  13. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    Hodge (24th August 2017)
  14. #10510
    Patrol Guru matfew's Avatar
    Nov 2012
    Sun?? what is this "sun" you talk about haha
  15. The Following 3 Users Say Thank You to matfew For This Useful Post:
    Hodge (24th August 2017), jack (25th August 2017), Winnie (24th August 2017)
