12th August 2017, 04:01 PM
#11131
I should have removed the brake drum heater my son made out of the rental house shed , have to be friggin bored to go into mine it's so cold .
12th August 2017 04:01 PM
12th August 2017, 04:46 PM
#11132
I'm not sure
Rossco
Hey @
Chappy car looks aweome by the way. Just had a couple of questions; I chucked one up earlier about the Bogard timer. About to put mine in just after how you worked out the wires to pick up from for the on position and start position on the ignition? Also are you still running your high mount if so how did you go getting the spotties to fit nicely.
Sent from my SM-T800 using Tapatalk
@Rossco I tapped mine into my Bogaard turbo timer (which was already installed on this new body). It was a case of tapping into the red and blue wires from the turbo timer. You will need to find out which wire is ignition & which is start coming from the key barrel and tap into that.
I have plates welded onto my bar which mount my spotties. The high mounts still on there (I need to wire it up though)
![](http://www.nissanpatrol.com.au/forums/images/imported/2017/08/88.jpg)
The Following User Says Thank You to Chappy For This Useful Post:
Rossco (12th August 2017)
12th August 2017, 04:51 PM
#11133
Rotaredom
The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
mudski (12th August 2017)
12th August 2017, 05:27 PM
#11134
Administrator
This swag is massive!
Just fits in the GQ!![](http://www.nissanpatrol.com.au/forums/images/imported/2017/08/89.jpg)
12th August 2017, 05:44 PM
#11135
The 747
AB
I could not close my doors with it sitting on the back seat like that. I had it in the bag though so it was wrapped up a bit tighter than that.
12th August 2017, 05:46 PM
#11136
AB
Would fit with ease acros the 62
The Following 4 Users Say Thank You to nissannewby For This Useful Post:
AB (12th August 2017), Clunk (12th August 2017), Maxhead (15th August 2017), Winnie (12th August 2017)
12th August 2017, 06:06 PM
#11137
Patrol Guru
Nah won't fit in a gq. Maybe you should go ask someone at the bottom of Barkly River jeep track how to fit it haha
The Following 2 Users Say Thank You to matfew For This Useful Post:
AB (12th August 2017), Rossco (12th August 2017)
12th August 2017, 06:16 PM
#11138
Administrator
Winnie
Yeah not ever using the bag, needs to be a bit loose like in pic and it's tight but just fits.
12th August 2017, 07:55 PM
#11139
Chappy
Ah cheers mate, yeah looks good just need to mount them a bit more forward but that works nice i recon. Cool will tackle the glow timer soon. In a world of wiring at the mo have quite a few gremlins might chuck a few more details in the other thread. . .
12th August 2017, 07:56 PM
#11140
AB
Yeah wow they're pretty big . . .
