Page 1035 of 1454 FirstFirst ... 35535935985102510331034103510361037104510851135 ... LastLast
Results 10,341 to 10,350 of 14534
  1. #10341
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Shitter has blocked up..... looking forward 2 a very expensive plumbers bill
    Family will just have 2 put up with the camp toilet until Monday so I can get the bill down a little
    Feb 2011
    Shed
    45 Post(s)
    Oh. I forgot, you have those. Sorry sweetheart
    Thanks for caring!
  4. The Following User Says Thank You to growler2058 For This Useful Post:
    katwoman (5th August 2017)
  5. #10343
    .......... TPC's Avatar
    63 Post(s)
    Not something yoy can fix yourself?
    As much as I hate plumbing work I do what I can myself to save money.
    I had a damaged pipe that I asked 2 plumbers to quote on and never got a response from either so fixed it myself.
  6. #10344
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Try one of these, could be a cheap option for you
    https://www.bunnings.com.au/kinetic-...-tool_p4900135
    They also have a $5 version you could use once and chuck out
    ...........on the road
    ________________________
    ______ 2017 D-Max _______
  7. The Following User Says Thank You to Maxhead For This Useful Post:
    NissanGQ4.2 (5th August 2017)
  8. #10345
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    That's why I built three bathrooms , only time I have trouble is because of the septic outfall pump , but have had to attack the odd dinosaur over the years , sometimes if the hmmm water level in the pan drops enough a good sized bucket of water upended in one go will unblock but it depends on the cause of the blockage and how squeamish you are .
  9. #10346
    Expert graeme1969's Avatar
    Jun 2013
    Wesley Vale, Tas
    Using a mop as a plunger in the toilet bowl works well to free things up.
  10. #10347
    Aug 2010
    17 Post(s)
    Prob could do myself, literally going 2 be a sh!t of a job though as the pipe has been covered with a sun-room and decking and not much room 2 work.
    I knew it was going 2 happen eventually as its blocked up over a year or so ago, bloody tree roots!!!
  11. #10348
    109 Post(s)
    Think you can hire roto rooters from bunnings or somewhere like that? Even ebay might be cheaper than a plumber then you have it in the kit?
  12. The Following User Says Thank You to Plasnart For This Useful Post:
    NissanGQ4.2 (6th August 2017)
  13. #10349
    I need to vent...
    The council have been pretty good to us so far in regards to our current issue we are having which a lot of you guys know about. They have given us a few extensions whilst we try and get a strong case together so we can hit these mofo's hard, giving them zero chance of winning a court battle. But now it seems they are turning. They want to inspect our property to see what works have been done. I told them theres no point as virtually zero has been done as we simply cannot afford the 5.1k for the drainage repairs. But they want to come so they are...
    So I get outside today and thought I will see what I can do myself so atleast it looks like things are moving faster. I then find another down pipe that is NOT connected to the storm water, they ( previous owners) had just put an end piece on the down pipe and covered it with garden mulch. So the council officer who inspected the property didn't find this. Then I go to where this down pipe is suppose to be going, joining up with the down pipe at the front of the house. I start digging only to find the 90mm pipe is all busted and they had just covered it over aswell!
    So. Now we have to call the plumber back in to requote, and then I have to ring our solicitor and tell him thats theres going to be more coin to chase. I'm guessing another 1k in extra repairs here.
    I seriously cannot wait until this is over.
  14. #10350
    43 Post(s)
    Thats pretty farked @mudski.
    Hopefully you get the a holes by the balls in time..
