Results 11 to 20 of 22
Thread: eBay intercoolers
    330 Post(s)
    Would be interesting to see how they flow tune on the inside, but this statement is a bit of a concern to me -
    Please note you will need to machine 2x extra ports as it will not line up with the standard pattern.
    Yeah I thought that was a bit odd too but they are bloody cheap and an error in the cast mould might be the reason why.
    North brissy
    No. That looks like its for a TB42 and bolts to the top of its intake manifold. It doesnt really address the area that needs attention when looking at manifold improvements.
  4. #13
    North brissy
    This is one more suited to a TD but it wont be $200
  5. #14
    583 Post(s)
    eBay intercoolers
    http://m.ebay.com.au/itm/New-Front-M...%257Ciid%253A7
    This is what oldmav ia using in his latest creation with no performance losses running just over 200rwkw and 700+nm of torque. He is also got his 0-100km/h time down to 7.6sec
    Hey mate do you know what bar OldMav has on that car?
    I can't measure properly until I take the grille off but I think I remember 300mm high IC was literally touching the ARB deluxe bar angle braces and was pushed up max just under the bonnet latch mechanism.
    I'm not 100% but just remember something about 300 being crazy tight!
  6. #15
    193 Post(s)
    Welcome to throw a tape measure over the golden horse while the grille is off if that helps. . .
  7. The Following User Says Thank You to Rossco For This Useful Post:
    AB (31st July 2017)
  8. #16
    583 Post(s)
    Your bars not on though is it?
    Those bloody angled supports come up on a decent angle and you lose a lot of space on the front that's all.
  9. #17
    193 Post(s)
    Can quickly throw the bar on for reference if you want . . .
  10. The Following User Says Thank You to Rossco For This Useful Post:
    AB (31st July 2017)
  11. #18
    North brissy
    Standard nissan. Thats on a gu though.
    Go back to post 4. The borg warner is insanely efficient so you can use something slightly smaller. I wouldnt go any thinner than 2.5" so you can keep that as your minimum pipe size but you could certainly go shallower to a 250 or 200 tall cooler. Basically use the biggest you can fit in their thats no thinner than 63mm
  12. The Following User Says Thank You to nissannewby For This Useful Post:
    AB (31st July 2017)
  13. #19
    583 Post(s)
    I'll do some hunting thanks Matty!
  14. #20
    583 Post(s)
    Thanks mate, might take you up on that, will your offset bar and your body lift match my spacing or will it give it me a false sense of security lol
