3rd July 2017, 06:22 PM
Injector pump DIY rebuild info needed
Thinking of replacing the leaking seals in my injector pump but am struggling to find good reference material , anyone out there know of any info or do you think I might be biting off more than I can chew ?
3rd July 2017 06:22 PM
3rd July 2017, 09:18 PM
Hi GQtdauto, You can buy a seal kit and replace the 'o' ring on the mixture adjusting screw and the gasket on the top lid. If that dosn't fix the leak, the pump will need to be taken out and sent to a specialist. Hope my thoughts help. Regards Kiwibob.
4th July 2017, 12:16 AM
KIWIBOB
It's the top lid o ring that's gone , I do have a complete seal kit and reckon I can do the top three it's just a bit of work removing the intake manifold so I can get at the flat screws etc , but if replacing all gasket/ o rings is a specialist job only maybe I better go that way .
I found some info and photos etc but can't find a parts diagram so won't attempt it unless positive I can do it without stuffing it up .
4th July 2017, 05:41 PM
Gday mate.
Is it a td42?
If so you won't need to take the manifold off to do the seals.
4th July 2017, 06:24 PM
Deano2506
Gday mate.
Is it a td42?
Yes it is a td4.2 , but unless the manifold comes off you can't get to the slotted screws holding the head of the injector pump and being loctite in only way to remove them is an impact screw driver and the manifold is definitely in the way .
If they used hex head bolts on all 8 fixings I could remove the top easy but slotted screws not possible unless I remove the pump .
Unless you have some other way I'm open to suggestions.
4th July 2017, 06:59 PM
I paid a diesel shop to do my top cover seal.
Cost me $230 all up.
I dont know what they used to undo the screws but the manifold definately didnt have to come off.
Perhaps you could give a diesel shop a quick call and ask em.
Good luck with it mate
4th July 2017, 07:04 PM
Thanks for that , will give my regular mechanic a call and see if he knows of someone in this area .
4th July 2017, 07:11 PM
4th July 2017, 09:31 PM
Yeah manifold doesnt have to come off to do top cover seal. Also replace the throttle shaft seal while you are there. The timer piston covers are easy to do on the side of the pump.
What you can do to make your life easier is mark the pumps location undo the retaining nuts and bolts and roll the pump away from the engine. This will help with access a little then just line the mark up after and tighten the fasteners.
It must be expensive in Hobart as the last time I had a shop do it up here it was $100. This being their minimum charge as the seals are worth about $4.
4th July 2017, 11:01 PM
nissannewby
Now that explains it , I was thinking no way can you get an impact driver on three of those screws without removing the manifold thanks for the tip .
One question though , won't I have to undo the injector lines to rotate the pump .
