26th June 2017, 10:06 AM
Removing Gearbox from GU TD42 Help
Hi all well still working on the GU ! I am a bit over the process ATM . its time to walk away and have a think about it .
I have been trying to get the gearbox out . I have read what I can about it here looking from under the truck I think I need to turn the gearbox anti clockwise .
to clear the starter motor casting on the bellhousing . ?
Its a heavy b of a thing ! I have the motor touching the firewall . I am thinking of removing the front engine mount ? is this a good Idea ?
I have been trying to download the GU manual and have not done to good so far . I t downloads but its all mixed up the pages are all over the place . I am no IT man . its just adding to the stress !
all for now Help is needed ! I run a machine shop and need to get it out of my sight before I burn it . thanks to all
m
Reason: Defined the title
26th June 2017 10:06 AM
26th June 2017, 10:39 AM
Moderator
Hi amte, i have changed your title to see if we can help you further. sorry i have never pulled a gearbox out of a TD42.
The manual is just a PDF. you should have no trouble. there are a number of versions and updates, try to download again or a different one see if that helps.
Check out my Toy -->
Rogue Dung Beetle
26th June 2017, 09:20 PM
haven't done a td in a gu but the 3L and 4.8's both required some massaging of the tunnel.
26th June 2017, 09:25 PM
Yeah good luck on removing the box on the floor. I did it, once. Took three of us and a bit of massaging of the floor on the drivers side was required. If done on a hoist with a trans jack the box can be twisted and it will come out easily enough.
27th June 2017, 08:37 AM
oh well sounds like I have found he hard way to do it ! AGAIN .! oh poo
have got it on a transmission Jack but I cant roll it around so will try putting a hoist through the floor .
think I might take an engine mount off on the drivers side it might also help .
The only thing I have going for the whole job is I can grind the flywheel myself .
I am driving my 1960 Beetle around what Fun it runs on the smell of an oily rag to and from work only $25.00 /week
The Following User Says Thank You to Tip12345 For This Useful Post:
27th June 2017, 01:01 PM
No no, removal is not really that hard once you know what to do.
1. Undo all associated bolts including tail shaft.
2. Unbolt and remove the shift cover from the top of the box. No chance with it on. If I recall I drilled 2 holes to make the job easier and put plugs in them.
3. Remove cross member.
4. Loosen engine mounts so it can tilt.
5. Motor needs to stay in place. Just tilt it. If it is against the fire wall you wont be able separate the bell housing from the motor.
6. Front end needs to be up as there is not enough room under the vehicle for the box to drop out. I use a fork lift.
7. Slide and turn the box as you go.....swear a lot. that b^&tch is heavy.
8. Make sure you do not try and catch it...I tried and hurt myself. So I suggest a box jack or a load of soft wood under it incase it falls.
I hope that helps buddy. I have done it and it is a pain in the arse.
I have some pics here:
The Following User Says Thank You to the godfather For This Useful Post:
Tip12345 (28th June 2017)
28th June 2017, 09:40 AM
got it willl try with the front engine mounts lose . I have had the forklift helping ! I have a transmission jack under it but its a bit of a hindrance. any idea where the balance point is.
28th June 2017, 02:28 PM
I used a engine crane in the passenger door and through the trans tunnel with a sling around the gearbox. Whilst it was still a bitch to remove, it was easier with the sling, than having it hard mounted on a jack.
Tip12345 (29th June 2017)
28th June 2017, 09:32 PM
Not really any idea on balance point. I dropped mine and it flaming hurt my shoulder.
28th June 2017, 11:54 PM
I believe once read a guru on here recommended using 2 x or maybe 3 chunky ratchet straps spanning the chassis rails for safe as possible under truck home effort!
the godfather (29th June 2017)
