Results 11 to 20 of 24
Thread: Servicing your winch
    Advanced Apples's Avatar
    Bacchus marsh
    WA Wheatbelt
    23 Post(s)
    Following.
    I've got a winch, but never used it in anger. Actually, I've never used it in 7 years. lol - for those that know me. PML
  4. #13
    330 Post(s)
    Quote Originally Posted by Apples View Post
    Hi Apples, I had look through the manual and yes it mentions Gear Oil. The gear Oil will have a thinner viscosity and will work better in the fast moving parts where they have recommended it.
    Interesting actually. I rebuilt my lowmount and just used CV grease everywhere, when I put it on the car and unlocked the free spool I couldn't pull out the rope. The slip friction from the thick grease locked it up. I stripped out the winch and swapped the CV grease for I think LMM grease to those moving parts and it made a huge difference. Next time I strip it out I will use gear oil.
    When in doubt read the manual.......
  5. #14
    Bacchus marsh
    Haha sweet ill give it a go and see how it works. Thanks for the info mudrunnerTD
  6. #15
    Millicent SA
    I have just finished servicing my Runva 11xp Premium winch, that is only 18 months old. When I first purchased the winch, I opened up the gearbox and cleaned out the factory grease which I was advised to do from others who had bought winches. My previous experiences with winches were all mechanical/gearbox driven.
    Anyway the reason I needed to service it was because the clutch handle had "jammed", it couldn't be moved in either direction. I had researched this problem, and found that some other Runva users had problems with water ingress through the clutch shaft under the handle. When I disassembled the gearbox and washed it out, there were signs of a very small amount of corrosion on the lock cylinder and on the main drum gear. The grease was only slightly emulsified. After 2 hours of swearing and heaps of inox and freeze spray, I eventually got the shaft out of the gearbox housing. It had rusted solid in the spring chamber. The shaft is pitted but the plunger is still ok. In the exploded diagram that Runva provide, there is no mention of a seal. I have emailed them for their input and possible warranty claim, since it is supposed to be ip67 rated. In the meantime, I have put it all back together with the spring chamber packed with grease. I will upload pics later, I have to work out how to downsize them (computer technically challenged here LOL). Anyway hope that may help others to remember to check that area as well as other usual servicing when having been in water. cheers Lana
    GU8 2012 Simpson anniversary model, 3" redback exhaust, 2nd primary filter (original secondary), provent 200, Scangauge, engine watchdog, remote uhf dash plug, DRL's, pillarpod with pyro and boost, Titan drawer system, tail light upgrade, more to come
  7. #16
    175 Post(s)
    Quote Originally Posted by shantillylais View Post
    Is your Runva winch the one like in this picture ???
    Because I'm about to do the same to mine . Except mines very stiff on freespool. But I've got warranty grounds there too so I can just send it in .
    But id like to do it my self to learn the ins and outs of it. See my thread about it here.
    http://www.nissanpatrol.com.au/forum...ad.php?t=40664
    175 Post(s)
    Also where did you get the blown up schematic of the winch from Runva ?
    My old TJM OX winch is stiff on free spool. Even after I serviced it. So I left it thinking thats how they are. I think I've used my winch maybe five times in five years. Everytime for bog holes. Now I just go around those.
  10. #19
    175 Post(s)
    I don't think it's right. Free spool should be "free" spool . When I contacted Runva first thing he asked was have I unwound the rope all the way out and back in to get everything lubed up inside , every 4-6 weeks like suggested in the manual .
    583 Post(s)
    Just serviced mine yesterday and the gear oil was milky damn it!!!
