28th May 2017, 05:16 PM
#7721
Yeti's Beast
How did you make your controller?
I once read somewhere that if your Waeco fridge controller throws in the towel, then modify your fridge with one of these
https://www.ebay.com.au/itm/271956087435
Yeti, apologies for the delay, been out all day shopping for a pair of chairs with my wife, 28,000 chairs later she selected the first one we looked at, can you believe that?
Anyway, here is the photo of the plastic box and the cheap ebay 20amp temp controller connected to the fridge using an Anderson plug, plus because i have such enormous faith in my electrical ability, I have a portable jumper lead so i can bypass the controller and use the Engel controller if it blows up.
Basically, the controller has two screen displays, one is your setpoint and the other is the actual internal fridge temp gained from the temp probe. The internal setpoint I run my fridge at is 1.5DegC. To get the controller to do the work instead of the crude Engel unit, turn the dial up on the Engel to freeze or wherever is past your setpoint, plug it into the external controller using the Anderson plug and you are away. the external control now modulates the temperature. I would think you could do this with the waeco as long as you can get power to the compressor motor. If the electronics are shot in the control board, you would have to do some re-wiring to drive the pump i think.
Here is the link to the item from an Aussie seller, but I think you can get them a lot cheaper ex China but longer delivery period. If you search 12V fridge controller there are a number there including the ones I have used and also @TD, but I have had mixed luck with those lately - some faulty parts and some due to clumsy workmanship on my behalf also!!
http://www.ebay.com.au/itm/12v-DIGIT...oAAOSwuLZY2w0WSANY0034.JPG
The Following 2 Users Say Thank You to PeeBee For This Useful Post:
MB (29th May 2017), Yeti's Beast (28th May 2017)
28th May 2017 05:16 PM
28th May 2017, 05:21 PM
#7722
Cheers and thanks for the detailed info. I would believe your day of shopping. We have been looking for a new couch since Jan. Each time we spend an average of 2-3 hours in a store and walk away empty handed.
One day she will find something she likes
28th May 2017, 05:35 PM
#7723
threedogs
on the outside of the chassis and body it might squeeeeze in up the front end.
If its a ute easier eh
Yes thinking up the front behind the winch somehow. Sides of chassis are out because already filled in those holes with storage boxes!
28th May 2017, 06:20 PM
#7724
Rotaredom
Winnie
Did they send it back to you with the spark plug tip removed?
No that's still in there
would of been nice if he could of removed it without taking the head off
28th May 2017, 08:20 PM
#7725
The Following 2 Users Say Thank You to gubigfish For This Useful Post:
MB (29th May 2017), NissanGQ4.2 (28th May 2017)
29th May 2017, 06:57 AM
#7726
Enjoying the trips
gubigfish
coated it in mud
Me too, underneath at least the rest is covered in dust.
A bloody good weekend out on the tracks.
Macca
![](image.php?s=dadae60996f8be2fba32c3b4f8481e41&u=962&type=sigpic&dateline=1361692028)
The Following 4 Users Say Thank You to macca For This Useful Post:
gubigfish (29th May 2017), MB (29th May 2017), Rossco (29th May 2017), Sir Roofy (29th May 2017)
5th June 2017, 02:06 PM
#7727
Patrol Goddess
Got a new beaut wanky UV screen fitted.
![](http://www.nissanpatrol.com.au/forums/images/imported/2017/06/37.jpg)
KATROL- The 2nd
GU TD42TGi
Silent member 1208
The Following 5 Users Say Thank You to katwoman For This Useful Post:
MB (6th June 2017), mudski (5th June 2017), threedogs (5th June 2017), Touses (5th June 2017), Yeti's Beast (5th June 2017)
5th June 2017, 02:14 PM
#7728
katwoman
What a great colour lol
5th June 2017, 06:33 PM
#7729
Installed my full length alloy roof rack. Bit of fiddling to get the legs placed right. Would have been easier with another pair of hands.
The Following User Says Thank You to Mc4by For This Useful Post:
5th June 2017, 06:35 PM
#7730
Mc4by
thinking about doing the same,heading off up north 1st july to see eldest daughter n grandkids......might take the boat aswell and just hello on the way through..lol
