Page 376 of 568 FirstFirst ... 276326366374375376377378386426476 ... LastLast
Results 3,751 to 3,760 of 5672
  1. #3751
    Jan 2016
    108L of diesel for the big girl.
  2. The Following User Says Thank You to Mungrel For This Useful Post:
    MB (21st May 2017)
    Aug 2010
    adelaide
    $100 diesel for me too at 112.7
    OH LEATHER IS NICE
  5. The Following User Says Thank You to my third 256 For This Useful Post:
    MB (23rd May 2017)
  6. #3753
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Flying trip to Townsville, left Childers 3.30 am Thursday loaded this at 4.30 pm same day
    This was first use at Duaringa on the Saturday morning.
  7. The Following User Says Thank You to Touses For This Useful Post:
    MB (23rd May 2017)
  8. #3754
    Beginner bushnbash's Avatar
    Jan 2014
    Gold Coast
    I bought some Titan rear drawers for the GU. Was going to make some myself but for $365 I don't think I could build them cheaper.
    2006 GU IV TD42TI 19X XXXkm,Turbosmart Turbo tuned(14psi),Boost gauge,K&N Airfilter,305/70r/17 Maxxis Bighorn,5" 45mm Adjust T D Sus,3" Exhaust ,JVC CD/DVD with Polk Audio,Warn XD9000 Winch,ARB Air Compressor, Chassis Rock Sliders,Dual Batteries,w/- IBS Battery Monitor System, Rhino Alloy Roof Rack. Mods to come, rear bar, new exhaust, rear drawers ect
  9. The Following User Says Thank You to bushnbash For This Useful Post:
    MB (23rd May 2017)
  10. #3755
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Purchased a CTEK Battery Sense blue tooth monitor. Uses an app on the phone to check battery charge and temperature. I assume it's ambient temp
  11. The Following User Says Thank You to Yeti's Beast For This Useful Post:
    MB (23rd May 2017)
  12. #3756
    Ballarat, Vic
    174 Post(s)
    I think you’ll find that the temperature reading is the temperature of the battery. An unexpected rise in temperature whilst the battery is charging can be an indicator of a problem. Battery temp sensors are usually just a lead attached to one of the terminals, so quite feasible that what you have bought can do this. Many of the better chargers have temp sensors attached to the battery in this way, & adjust the charging voltage dependent upon the temperature. This helps to extend battery lifespan.
    Out of interest can it tell you how many amps are going in or out at any one time?
  13. #3757
    Aug 2016
    Jimboomba
    4 Post(s)
    Thanks Cuppa, unfortunately it only shows Volts and temp.
    Just did a quick trip to the shops and back and it seems to work
  14. #3758
    My cable end protector arrived pretty fast if you ask me.
    I had one of these ,but would not like to get hit in the head with it
    http://www.ebay.com.au/itm/231011324...%3AMEBIDX%3AIT
  15. #3759
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    Did I read somewhere Cuppa, that you have a Victron BMV-702 monitor for your batteries? If so, they have a BT dongle that plugs into it now, that will tell you this. This is how I monitor my batteries/solar panels, while sipping a bourbon in my camp chair. It sends the data to my phone. http://www.ebay.com.au/itm/VICTRON-V...-/281752240958
  16. #3760
    Ballarat, Vic
    174 Post(s)
    Quote Originally Posted by stevemc181 View Post
    No Steve, I have a NASA BM1 battery monitor which counts amps in & out & shows real time amps in & out. (Uses a shunt). I wish this sort of phone technology had been available when I installed my set up. It would have far easier & saved me a bit of grief. How does the app calculate SoC? Do you have to input the battery size when setting it up?
