Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Evening ppl
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Evening ppl
    Can any body tell me what size bolt I need for
    for the engine mount brackets are they fine
    thread or course thanks in advance
    its a 3l Di
    SUCH IS LIFE Maxhead's Avatar
    ACT
    I wonder if they have the size in the service manual Roofy?
    ................on the road
    ________________________
    ______ 2017 D-Max _______
  4. The Following User Says Thank You to Maxhead For This Useful Post:
    Sir Roofy (8th May 2017)
    TRAFALGAR VIC
    35 Post(s)
    Looked in the gregorys manual just says for bolts
    might be 9/16 ill know better once I get it apart
    ACT
    Quote Originally Posted by Sir Roofy View Post
    I just checked the normal manual and they seem to have torque specs but not bolt sizes.
    Bloody hard manuals to navigate..lol
    175 Post(s)
    I'm sure mudski has some new mounts ... He can check bolt sizes , measure up etc ... Maybe ? @mudski
  9. #6
    TRAFALGAR VIC
    35 Post(s)
    Not wrong there we will survive mate
  10. #7
    TRAFALGAR VIC
    35 Post(s)
    Thanks mate have to wait till he's free I guess
  11. #8
    465 Post(s)
    The mounts don't use bolts, they have studs in them. The bracket is bolted to the chassis. I just check the parts catalog and theres no size written. They will be a metric fine thread. Are all the bolts missing? both sides? I think they are a 14mm head on the bolt, which should be a 12mm (1.5 pitch I think) by maybe 20mm in length. If you can get another out you can use this for reference.
    11298VB912 for LHS and 11298VB913 for RHS, are the OEM numbers. 4 each you need for both sides. Not sure why they are different part numbers, most times I see this they are the same part, just different numbers. See if a local Nissan dealer ship can get them? They might be cheap enough from them for the right ones.
  12. #9
    TRAFALGAR VIC
    35 Post(s)
    Thanks mate yea four bracket ones where missing the ones that bolt to the motor
    was very lucky the motor didn't twist out
  13. #10
    TRAFALGAR VIC
    35 Post(s)
    ITS done now I have to wash the blood off the motor and me
    hate 3l motors with a vengeance
    shouldn't come loose this time used lock tight
  14. The Following 5 Users Say Thank You to Sir Roofy For This Useful Post:
    Bob (10th May 2017), Hodge (8th May 2017), MB (8th May 2017), mudnut (8th May 2017), Rossco (8th May 2017)
