Question how close to the battery do these things have to be, 600mm-900mm
enough??? no eye dear lol
As close as possible & practical. However NOT inside a small enclosed space WITH the battery where gas could build up. Although most unlikely you should never risk putting ANY electrical equipment which has a potential to create a spark in an evironment which could possibly become explosive. With AGM/Gel batteries the risk is minimal, but they can gas in some situations. The risk is far higher with wet batteries.
Wet batteries should never be inside the vehicle.
2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare) A Nomadic Life (Blog)
There's a handy excel spreadsheet on the myswag forum that helps calculate expected amp usage for various things (fridges/lights etc), then you plugin your batteries/panel sizing etc and will give you estimate usage rates, how many days you'll get out of x etc. Its good kit.
where would you mount it, Im thinking of mounting my mppt somewhere
inside the bullbar on the AUX battery side,
I mounted mine above the glove box, out of sight and can be accessed easily if needed. My aux batt is under bonnet so as close as I could while remaining out of elements and engine heat. If I had a rear battery which may happen one day, I would relocate to the cargo barrier.
I already have some decent sized cable coming from
the Aux battery to the bullbar a run of about 500mm,
terminating at a 50amp anderson plug. I should be
able to wire my weather proof MPPT reg up inside the grill
I think. Also need to change the 50 amp anderson to a fully fitted job
Still playing with the setup on the GQ , might pee off the 20 watt and just use the 100 watt for now .
Just have to solve the age old question of where to put the reg without running the wires too far although it looks like yours is sorted .
Thinking that the trip to the corner country next month will let me know the problems with the system if any and then I can fix it before next years 6 month trip hopefully to the cape .
Fancy looking Anderson plug you have there .
Like you I have a small 10 watt panel, Im thinking that would be OK to hook up to
start battery to keep it "busy",
Must also figure out how to have a solar outlet at the back I have that cig,merit and guage
for the small cut out, this would come in handy depending on the camp site,,
position of the sun etc, somehow I need to get my Patrol fixed first.lol
Yeah everyone's rig is setup slightly different TD , and we all have our own ideas sometimes right sometimes wrong .
Still haven't finished my setup I'm busy doing other stuff and charging up a mates dead ride on mower battery which has gone from 5 volt and .1 amp to 11.65 volt and .78 amp after one full day on the GQ 100 watt solar and holding .
So will keep it up for a couple more days and see if it restores the battery , I notice the equalisation charge is pulsing 16.5 volt into it to try and shock it into life .
