1st April 2017, 10:41 AM
60w powerfilm foldable solar panel
Will my 60w powerfilm solar panel run 60L engel fridge/freeze ?????
1st April 2017 10:41 AM
1st April 2017, 11:53 AM
Hello and welcome to the forum , when you get a chance pop over to the intro and tell us a bit about yourself
before asking questions,, polite and all, no harm done, I think 60 watts may be a tad small for such a big fridge
100watts would suit it better IMO
1st April 2017, 12:04 PM
threedogs
Agree TD, I have 120W on my roof and it caters well for the 60L engel, in fact been doing it for just on 20yrs now. Its a Canon Shade tolerant panel - 2 x 60W, solar cells laminated onto SS sheet, so no glass to break if something falls on it, ot the roofrack twists.
1st April 2017, 01:31 PM
I'm sorry about the way I started I'm only new to this app. Sorry if I offended anyone.
1st April 2017, 01:36 PM
1st April 2017, 02:05 PM
lugga9
Here you go mate,,,
http://www.nissanpatrol.com.au/forum...-Introductions
1st April 2017, 07:30 PM
Travelling Podologist
FRom Engel's web site - the 60L fridge freezer - "DC Power Consumption Variable from 0.5 to 4.2 AMPS Maximum
1. The amps it draws will be dependent on a number of factors - how cold you run it. Colder uses more power. Ambient temperature. It will use more the hotter the day is. What you put in it - if you put warm stuff in to cool down it will use more. How often you access it - if you are frequently opening the lid to get another beer it will use more power.
2. The amps Engel claim will be what it uses when it's running. It will cycle on & off - how often will be dertermined by the above.
If you consider a not unusual running time of 50% - that's 12 hours a day. At that rate the fridge can use up to 12 x 4.2amps - that equates to a tad over 50 Ah over 24 hours which you need to get back into your battery. (which sounds about right to me). Your 60w panel, on a good solar day, & if connected with suitably heavy cable & the regulator near the battery (not on the rear of the panel) will be able to put around 25ah to 30Ah into your battery. Of course not every day is a good solar day, & the number of 'solar hours' is less in winter & in the south. Better to work on the panel giving 15 to 20Ah. To reliably run that fridge (& nothing else) at any time of the year, in any part of Australia you need 3 of those panels. This will be sufficient to bring the battery back to full charge every 24 hours. You could get away with 2 of those panels if only needing to run the fridge for weekends away, arriving home with a battery in need of charging.
1st April 2017, 09:53 PM
Thinking back to our trip to the Kimberley in 1997, we did struggle on capacity as the temps were high at night and the fridge needed to run with no solar top-up, then it was running a high proportion of the day due to base camping and little sun. A third panel would have helped for sure, but not enough room on top to mount. Since then, just doing trips in the southern parts, the 2 panels have sufficed.
2nd April 2017, 08:09 AM
If you are driving every 2nd day that will help out the Aux battery heaps.
If you're camping in one spot for a long time say a week then you may struggle
topping up the battery.
When I went to Birdsville with a few mates we took an esky for the cold drinks
as we knew we would pass a servo every day so ice was available. I froze 2 roasts
before I left and placed them in the Engel ate one the other was still frozen when I
got home.
I think Engels figure of 4.2 amps is a little low,,
real world usage would be more around 6 ah IMO
If you're driving more than 2hrs every 2nd day you might get away with it ,,,,,,,,just
2nd April 2017, 09:03 AM
The Following 2 Users Say Thank You to Cuppa For This Useful Post:
lugga9 (2nd April 2017), PeeBee (2nd April 2017)
