Page 8 of 10 FirstFirst ... 678910 LastLast
Results 71 to 80 of 98
Thread: Getting hot after Dawes needle and 3"
  1. #71
    475 Post(s)
    For sure, does sound like a prick of a TS location, best of luck with it Friday Growler! Rainsey over in the Chev thread reported recently very similar symptoms on his 6.5. Brunswick and him found the viscous fan was the culprit in his situation not fully locking up I believe under load on hills and had them totally baffled for a while.
    Feb 2011
    Shed
    45 Post(s)
    Well ive got it back but haven't taken it up a hill yet. Will do that tomorrow. Sssssoooooooooooooooooo. Thermostat was stuck between open and closed WTF???. @MB they also serviced the viscous hub, rekin it wasnt spinning fast enough?? Dont know if theyre having a lend or not. Coz wouldnt it stay cool @ 100k's even without the fan running with the volume of air blowing in. And get hot at the lights without air flow, which was oppsite to my symotoms?? Anyway they tested it and rekon its good now. I'll report back tomorrow
  4. The Following 4 Users Say Thank You to growler2058 For This Useful Post:
    AB (31st March 2017), Bacho86 (31st March 2017), MB (31st March 2017), TPC (31st March 2017)
  5. #73
    475 Post(s)
    Great news Growler, see you at the donk party hopefully! Sounds like you may have scored a double wammy mate, TS & Viscous working together for a complete pain in da :-( I'm not exactly sure how mechanics test the viscous hub at full temp and rpm 100% lock up, timing light and white marker crank versus fan maybe? With Rainsey's issue they supplied a solid van hub to run constant just to prove it was the viscous hub lacking say the last 10% pull I guess.
    growler2058 (31st March 2017)
  7. #74
    .......... TPC's Avatar
    63 Post(s)
    Sure hope that's the problem solved.
    Between the door lock and the overheating you have been cursed with this car.
  8. The Following 2 Users Say Thank You to TPC For This Useful Post:
    BigRAWesty (2nd April 2017), growler2058 (31st March 2017)
  9. #75
    Feb 2011
    Shed
    45 Post(s)
    2 simple things that were an absolute arsehole to sort out
  10. The Following User Says Thank You to growler2058 For This Useful Post:
  11. #76
    175 Post(s)
    Just curious, was a genuine thermostat used ?
    Sent from my SM-N910G using Tapatalk
    475 Post(s)
    I feel your pain mate, try buying a 6.5 Chev/Trol as a rushed heavy haul replacement for your written off 4.2TD but soon after find it was so poorly setup and I'll guide you on how to burn $5k+ real quick getting it work usable :-( Cooling all our modified trucks is a challenge but rewarding when you've nailed it :-)
    growler2058 (1st April 2017)
  14. #78
    Feb 2011
    Shed
    45 Post(s)
    I dunno mate I'll look at the invoice, my missus picked it up yesterday
  15. #79
    Feb 2011
    Shed
    45 Post(s)
    Just checked and it says new thermostat to suit? But PHARK me it was $56!!!!
  16. The Following User Says Thank You to growler2058 For This Useful Post:
    Maxhead (2nd April 2017)
  17. #80
    lucky bugger you were sold the Gold TS,,,, cant get better than that,,,lol
    Hopefully its sorted now, AHhh the complex ZD30
  18. The Following User Says Thank You to threedogs For This Useful Post:
