Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 98
Thread: Getting hot after Dawes needle and 3"
  1. #41
    Nah now im at work. Sprayed with wd40 but it just burns off. I need to take the WD to work spray the bastard when its cool and try again in a few hours
    sounds like a good plan ,been hearing they are a biatch to get off some times
    did it occur to you to loosen it when it was on the grass,,,lol
  2. The Following User Says Thank You to threedogs For This Useful Post:
    growler2058 (16th March 2017)
    465 Post(s)
    Certainly odd this one. I think it has to be coincidental. Incorrectly tuned valves could result in high EGT's, but not water, I would think.
    Ìm going to go back to this. High EGT will result in higher water temps.... I was driving my Patrol yesterday and I noticed myself subconsciously looking at the EGT's rising as I was going up a steep hill and then watching the water temps also rise. The both drop as I came off the top of the hill.
    I then remembered back, driving up the coast with the camper and knowing exactly when the water temps would start to climb just going by the EGT's. For mine, it was when the EGT's passed 260c the water temps would go up, and go up by 5degs by every 30 EGT's or there abouts...
  5. The Following 3 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (18th March 2017), growler2058 (17th March 2017), threedogs (17th March 2017)
  6. #43
    43 Post(s)
    This has a lot to do with cooling system condition.
    In older systems it makes total sense to see water raise with egts. The engine is working harder, and hotter so the water would be heating up..
    But if your cooling system is in good nick you may notice nothing.
    I've seen 650 on the egts yet water temp didn't budge off the normal 89-91 range. .
    @growler2058 where you up to or too busy elsewhere ?? lol
  8. #45
    Feb 2011
    Shed
    45 Post(s)
    Just nursing it till I get a day off. Temp status 88C driving on flat ground at 100. Will have a go at getting the egt on again today
  9. #46
    465 Post(s)
    Yeah you may, but may not too. The cooling system in mine is better than stock and i see fluctuations. But its a totally different motor so its kinda null comparing mine to this.
    Get the egt gauge in first i reckon and it may show us something.
    BigRAWesty (19th March 2017)
  11. #47
    43 Post(s)
    That is also true lol.
    Feb 2011
    Shed
    45 Post(s)
    Taken the dawes and needle off and STILL running HOT!
  13. #49
    Unafordable
    4 Post(s)
    So indeed, you mentioned the cooling system was worked on recently? I know for the fact that ZD30 cooling system is very difficult to purge of the air unless done correctly. However that shows up very quickly or can, you may wanna investigate that too.
    I can have 500°C EGTs on uphill climb at 100 km/h and coolant temps will not go over 92°C at 40°C ambinet temps.
    So for those of you getting coolant temp rise withm the rise in EGTs the cooling system is marginal at best. ZD30 radiator size is good enough for LS2 V8 conversions.....
    Regards
  14. The Following 2 Users Say Thank You to Rumcajs For This Useful Post:
    growler2058 (20th March 2017), threedogs (20th March 2017)
  15. #50
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by Rumcajs View Post
    Regards
    Million $ Question then, is how or what is the best way to bleed the air out?
