Page 738 of 1054 FirstFirst ... 238638688728736737738739740748788838 ... LastLast
Results 7,371 to 7,380 of 10538
  1. #7371
    Bloody hell, would be a shame for that high compression to be ruined by his old turbo. Ticking time bomb really!
    I'd be slapping a new Borgwarner on that asap Rossco to prevent some serious damage mate!
  2. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    AB (11th March 2017), Rossco (11th March 2017)
    193 Post(s)
    We just did a compression test on Rosscos TD42 and it did well.
    400-370
    One very happy little Rossco camper!
    Yep cheers heaps AB & MB☺ . . . Actually did better than I expected to be honest quite happy . Thinking might do a trip or two in April then time to pull the thing apart and strap on a borg warner get the old girl to wake up a bit i think. . .
    Sent from my SM-T800 using Tapatalk
  5. The Following User Says Thank You to Rossco For This Useful Post:
    threedogs (11th March 2017)
  6. #7373
    Yeah he was concerned with possible condition of engine and now with his 12mm pump and a tired old turbo it's just a given.
    Surely his mrs will agree lol
    thinking it must be a safety issue some how lol lol surely
  7. #7374
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Removed the rooftop tent and put a door in the cargo barrier so the mossie awning would go on the shelf I made for it .
  8. The Following User Says Thank You to GQtdauto For This Useful Post:
    threedogs (14th March 2017)
  9. #7375
    Advanced juzzs8's Avatar
    Gold Coast, QLD
    Hey mate where did you get that bracket for your LED bar? Currently got mine bolted straight to the round tube of the roof rack and don't like it at all. Your bracket looks the goods!
    2010 GU7 3.0L CRD
  10. The Following 2 Users Say Thank You to juzzs8 For This Useful Post:
    GQtdauto (14th March 2017), threedogs (14th March 2017)
  11. #7376
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    Put a new OME steering dampener on. Didn't realize how sloppy it as before. Don't know if it was the original but was stamped Nissan and had little compression.
  12. #7377
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Quote Originally Posted by juzzs8 View Post
    Its leftovers from the cargo barrier , or 25x3mm flat , bracket is about 100mm long on top and 90 degree bend bit was just long enough to fit the light bracket , even the existing hole in bracket was in the right spot .
    I need to replace the roof screw with a bolt ,so two bolts on top of bracket holding it to roof rack and I have put one roof screw on the bend so it holds tight and won't shake off , pics below of bracket .
  13. The Following User Says Thank You to GQtdauto For This Useful Post:
    juzzs8 (14th March 2017)
  14. #7378
    You can type in lightbar or bull bar brackets that should find the correct size bracket for you
    http://www.ebay.com.au/itm/251885300...%3AMEBIDX%3AIT
    You can even find some that will mount sideways
    I welded tabs onto my roof rack
  15. The Following User Says Thank You to threedogs For This Useful Post:
  16. #7379
    Gold Coast, QLD
    Sweet as. Cheers mate!
    2010 GU7 3.0L CRD
  17. #7380
    This style will suit vertical mount where as the others would suit a horizontal mount.
    http://www.ebay.com.au/itm/Pair-2-Bu...cAAOSwhOVXdyp2
  18. The Following User Says Thank You to threedogs For This Useful Post:
    juzzs8 (15th March 2017)
