Results 11 to 20 of 34
Thread: No power under load while on petrol
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Just a little more info on the TB45E ECU data. Disconnecting the battery will only erase the STFTs (short term fuel trims). These are very quickly relearned by the ECU.
    Erasing the LTFTs (long term fuel trims) requires a Nissan Consult device or can be done with an Ecutalk cable and ODB Scantech software on your laptop.
    Long term fuel trims are learned over a longer period (hence why the factory didn't allow erasing every time you disconnect the battery for some unrelated reason) and are not easily influenced by a sudden problem unless it's allowed to persist for a while.
    John
  2. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    dom14 (10th March 2017), jay see (10th March 2017)
    you can plug in my ECU-talk if you want and delete any errors ??
  5. #13
    49 Post(s)
    Thanks John.
    Yours won't suit my plug.
    Found this last night.
    Didn't know that there's one to suit.
    Might have to invest in one.
    Can any please confirm that my maf sensor is alright, does the wire not being straight affect it's operation?
  6. #14
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    Im pretty sure as long as its connected either side and not snapped it should be fine.
    May need to check out the 02 sensors. Check the timing too
    2002 GUIII Ti 4.8
    Details here
  7. #15
    @Roofy suits Bobs
    that one you showed is the same as mine,
    cant see why it wouldnt suit
  8. #16
    49 Post(s)
    Quote Originally Posted by Mike02Ti View Post
    That's my thinking too. I think I'm just trying to pinpoint something that's wrong.
    Wouldn't 02 sensors throw up a engine light?
    Timing was done a few weeks back.
    @Roofy suits Bobs
    Different plug connection. My is consult port yours would be obd.
  9. #17
    Jun 2016
    Rockingham WA
    4 Post(s)
    Not necessarily. If the 02 sensors functioning somewhat they may not throw a code.
    Mine on my 48 are buggered. Using about 30l/100km.
    No code or engine light but all over the place when i read them with NDS II. Runs great on gas though.
    Also check the cat converter and see if its blocked
    2002 GUIII Ti 4.8
    Details here
  10. The Following User Says Thank You to Mike02Ti For This Useful Post:
  11. #18
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    @jay see
    I have ECU talk and OBD Scantech loaded on a Laptop together with Connecting Cable to OBD Port.
    You are quite welcome to use
    I have a 1998 4.5 Litre Patrol so it should be compatible with yours.
    I live in Pakenham
    Regards
    Bob
  12. The Following User Says Thank You to Bob For This Useful Post:
  13. #19
    49 Post(s)
    Quote Originally Posted by Bob View Post
    @jay see
    I live in Pakenham
    Regards
    Bob
    Thanks Bob, is yours a consult port grey 14 pin?
  14. #20
    Oct 2010
    Pakenham
    47 Post(s)
    Yes it is
    @jay see
