3rd November 2014, 04:47 PM
#141
Patrol Guru
I just used the rubber part, so only a slight improvement in noise reduction,
But I didn't think the GU was to bad anyway.
2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
3rd November 2014 04:47 PM
27th August 2015, 03:52 PM
#142
Interesting reads here. I know this is an old thread, but I'm about to start this process with my 99 GU. Except, the goal is thermal insulation instead of just sound dampening. I know there is some overlap between the 2 goals, but thermal insulation is of the utmost importance here in Siberia when dealing with the winter conditions. Will have to post up some progress pix as I get into it.
The Following 2 Users Say Thank You to SiberianPatrol For This Useful Post:
BigRAWesty (27th August 2015), Majestic (27th August 2015)
19th January 2016, 10:52 AM
#143
SiberianPatrol
So how did your job finish mate??
I must say I'm still very happy with my end result.
And now three the summer the car ac works much better.. you still get heat coming threw when the car is resting in full sun, and viscera with cold, but the temp changes much quicker and holds much better.. instead of having ac flat out once down to temp it's comfortable on nfan speed 2..
The Following User Says Thank You to BigRAWesty For This Useful Post:
Kimbo63 (19th January 2016)
16th February 2016, 03:09 AM
#144
Hey Westy, I can't get Dynamat over here but there is a company that can do a spray on rubber liner - same as what you would use in the back of a ute - do you think this would work for some sound deadening if used under the carpets?
16th February 2016, 06:10 AM
#145
It may.. any material stuck to the body is "mass loading" the pannels, it's just how much mass is added.
I noticed a small difference when I painted my rear 1/4 pannels with the paint on stuff..
It didn't do as good a job as the dynamat but it did something..
16th February 2016, 01:01 PM
#146
Its an oldie but a goodie is to stuff some
acoustic batts inside the rear 1/4 panels.
You'll be surprised the difference it makes.
BigRAWesty (16th February 2016)
23rd February 2016, 03:47 PM
#147
biggqwesty
Westy, sorry I didn't see this until now. Yes the job is finished. I used a product over here called Shumoff - a dense 10mm self-adhesive insulation. Insulated the roof, pillars and sidewalls of the cabin. I didn't do the floor because the GU already had a thick pad and carpet. If it still gets cold, I'll go ahead and do the floor as well. I noticed a definite sound dampening and it so far has held the heat very well in -40C temps. So far I'm very pleased with the results.
The Following User Says Thank You to SiberianPatrol For This Useful Post:
BigRAWesty (23rd February 2016)
9th March 2017, 07:00 PM
#148
hey guys,
i'll be adding some sound deadener/thermo proof on the weekend. just wanted to ask if you guys have suggestions on what to paint the floor pan with? really want something that will seal the floor pan but not smell on hot day's.
cheers
9th March 2017, 07:53 PM
#149
painter recommended to me use body Schultz. under the car haven't done it yet so cant say how good it is
9th March 2017, 11:46 PM
#150
Yeah i was more talking about coating the inside of the cab/floor pan, im interested in a primer/sealer before i lay the matting.
