20th February 2017, 09:00 AM
#21
PBBIZ2
Re HID Hi/Lo, I just got pinged for my HID Hi/Lo's - not legal in Vic - maybe you are already aware? Heaps better than any halogens I have found, but that is irrelevant in the eyes of the law - just a heads up. Now have to swap them back to the old lights.
been meaning to change them as they have burnt the reflectors from being too hot
Dont drive much at night. Ill probably change them very soon to a OE set up
anyone running LED headlights and are they legal ??
20th February 2017 09:00 AM
9th March 2017, 05:30 PM
#22
Hey fellas, just bought a 42' and 2 x 6's. Just wondering how you blokes mounted them. Looking at mounting to underside of roof rack also. 42' at front and the 6's at the back for setup lights ( also trying to work out how I could mount the 6's to spin 90* to side of car for setup also if have any ideas?
Cheers!
9th March 2017, 06:15 PM
#23
Go back one page and look at photos I posted , under roof rack at front is what I have done the two smaller ones replaced the big spotties that were restricting air flow to radiator but I also got rid of the oversize "Nissan" badge as well and notice the difference.
The Following User Says Thank You to GQtdauto For This Useful Post:
9th March 2017, 06:20 PM
#24
Sorry. Meant like mounting brackets etc. did you use pre existing holes in rack or make your own? I've seen some ppl just cable tie there bars on. Others got extended bits of flat steel to reach out to the mounting brackets on the bar
9th March 2017, 06:21 PM
#25
Was just wondering what you fellas did.
9th March 2017, 06:31 PM
#26
I actually used the spare brackets that came with the cargo barrier I bought , just a bit of heavy flat with a right angle bend , it's bolted on using two bolts with nyloc nuts and one metal screw per bracket , that is it will be when I replace two screws with bolts .
Vibration from corrugations is a killer on roof racks and accessories if not fixed down right .
