Page 736 of 1053 FirstFirst ... 236636686726734735736737738746786836 ... LastLast
Results 7,351 to 7,360 of 10524
  1. #7351
    Adventurist stevemc181's Avatar
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    Bit by bit slowly detailing it for the meet up, its just these bloody faded bumpers that drive me crazy
    I'll try @Winnie solution and rub some thin oil into them
    Best I mount my 42" single row light bar to the passenger side of the Patrol best set up light EVER lol
    This Autoglym Bumper and trim Gel is the ducks nuts for bumpers/snorkels etc. http://www.supercheapauto.com.au/Pro...l-325mL/383925
    2016 GU Legend Edition: 3505Kg GVM Upgrade and Stuff!
  2. The Following User Says Thank You to stevemc181 For This Useful Post:
    threedogs (6th March 2017)
    I'll give it a go on your recommendation tomorrow on the way back from the Docs
  5. #7353
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    made a bracket to hold the air intake ducting so it doesn't rub on the alternator.
  6. #7354
    Also cable tie any aircon hoses or catch can hoses together so they wont rub through
    Even hoses just resting on top of one another will cause damage
  7. #7355
    Jan 2015
    19 Post(s)
    whats a catch can ? :P it was the only loose thing in the engine bay. will be doing a relay for each headlight later when i have time. but thats about it in the engine bay.
  8. #7356
    applied some perforated black window film to the inside cargo window
    on the passenger side, it will be done in 2 pieces but will be un detectable
    when finished. should allow the fridge to work a bit more efficiently lol
  9. #7357
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Finished the storage for beside fridge , hardwired thumper max in behind storage slide out box and wired switch to centre console .
    Have put a ball valve in between pump and inflator so I can check how pressure is going without having to turn pump off .
  10. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    juzzs8 (10th March 2017), Touses (10th March 2017)
  11. #7358
    Quote Originally Posted by stevemc181 View Post
    A momentary switch would mean I would have to keep it depressed to keep the lock-up engaged, I will sometimes have the lockup engaged for an hour or two at a time, so that isn't going to work. It's just a standard carling type SPST rocker switch. I'll mount it within easy reach somewhere, probably down near the shifter. I thought about having it on the sloping bit of the centre console arm rest thingy, but I think it may get knocked too easily there.
    They way I saw it was you pushed the button if ever you came to a stop.
    As soon as you got going again you'd take your foot off it,,similar to a clutch
  12. The Following User Says Thank You to threedogs For This Useful Post:
    GQtdauto (10th March 2017)
  13. #7359
    Good to see you have the photos up the right way around, if fitting a tank
    I'd be fitting a one way valve to stop the pressure releasing back through
    the compressor, Good value those pumps, I have one pump that cost me $600 plus
    from Big Balls Off Road, not even close to my single headed Thumper
  14. #7360
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Thanks threedogs , to be honest now I've tried it out with the ball valve on the inflator I'm impressed as to how good these pumps really are .
    May put a tank on it and a line under roof rack both sides , just open sliding window and connect short hose to supply air from compressor.
    Love they way it cuts out by itself at 150 psi and restarts at just under 100 psi , it's amazing to hear the air rush in just from the line .
    Might do some investigating to see if I can set it up like a servo , ie set to 16 psi it automatically lowers pressure , set to 40 it automatically sets to that then cuts out .
    More than happy with it and now the pumps fixed in position out of the way and hard wired so the only mucking around is the hose .
