2nd March 2017, 05:34 PM
#7341
threedogs
if it looks the same as Growlers ,,,whats the issue ???
They both only have a 2" dump pipe.
The Following User Says Thank You to Firetrol For This Useful Post:
threedogs (3rd March 2017)
2nd March 2017 05:34 PM
3rd March 2017, 10:17 AM
#7342
stevemc181
I wired my Wholesale Automatics Torque Converter lock up switch module into the Transmission ECU harness. Not quite complete, need to finish it off and work out where I am going to mount the switch in easy reach. I just have it hanging loose at the moment as I ran out of time.
Dont you put a momentary button on the foot rest??
3rd March 2017, 12:29 PM
#7343
Nearly finished the extra storage in the back , made use of the old fridge slide and put a Plano marine storage box on it , pulls out further than needed to get at the rear latch , still have to mount compressor in behind storage box which will be switched on off at centre console .
Storage above box is for two floor mats , one for mozzie tent floor other for camper trailer annexe , with just enough space left for mozzie tent .
Portable solar panel will go against divider on right side and chairs between that and side windows .
Still have to paint the unit and fit aluminium strips around the edge , will also make a hinged door above storage shelf in cargo barrier so I can access top shelf from either side .
When and if I ever finish will post some more pics .
3rd March 2017, 12:35 PM
#7344
Adventurist
threedogs
A momentary switch would mean I would have to keep it depressed to keep the lock-up engaged, I will sometimes have the lockup engaged for an hour or two at a time, so that isn't going to work. It's just a standard carling type SPST rocker switch. I'll mount it within easy reach somewhere, probably down near the shifter. I thought about having it on the sloping bit of the centre console arm rest thingy, but I think it may get knocked too easily there.
2016 GU Legend Edition: 3505Kg GVM Upgrade and Stuff!
3rd March 2017, 12:39 PM
#7345
there is room to the Right of your auto stick I think on the later model
4th March 2017, 04:55 PM
#7346
Installed the additional 2 temperature probes on the oil filter and the oil cooler, replaced the super accurate temperature controller for my old 60 liter engel - drowned it when the water from the water tank splashed out of the inlet filler hole on the caledonia trip - some turkey left the lid off the tank, saw him in the mirror reflection this morning, made a 'stay' for the rear wheel carrier to stop the wheel wobbling back and forth - braced to roofrack - works a treat. drank 8 beers during the process and everything looked great at the end
4th March 2017, 05:45 PM
#7347
Finally been well enough to stand and give the Patrol a well over due wash.
came up a treat, big polish tomorrow if all goes well, lol
Tomorrow off the Super Cheap to put a hole in my $100 gift card
4th March 2017, 05:49 PM
#7348
threedogs
You washing it for the Meetup John ?
The Following User Says Thank You to Hodge For This Useful Post:
threedogs (4th March 2017)
6th March 2017, 05:30 PM
#7349
Hodge
Bit by bit slowly detailing it for the meet up, its just these bloody faded bumpers that drive me crazy
I'll try @Winnie solution and rub some thin oil into them
Best I mount my 42" single row light bar to the passenger side of the Patrol best set up light EVER lol
6th March 2017, 05:58 PM
#7350
Adventurist
