Page 734 of 1056 FirstFirst ... 234634684724732733734735736744784834 ... LastLast
Results 7,331 to 7,340 of 10551
  1. #7331
    175 Post(s)
    I got a hot dog welded in today. I was looking for a median sound between my muffler and the straight through. Straight was way too loud, and muffler blocked out everything...
    I think i achieved it. Hot dog gave me 10db less than straight through but still retained that 4.2 growl without the that harsh loud shriek sound. So far happy.
    Side effect: The whistle was cut out big time.
    Quote Originally Posted by Parksy View Post
    Almost finished tinting. I left the front windows to show the comparison.
    You must have the cleanest Patrol of all ,,, well since they started making Patrols
    Ive never seen one cleaner, Kudos to you. love the tint too BTW
  4. The Following User Says Thank You to threedogs For This Useful Post:
    Parksy (27th February 2017)
  5. #7333
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by gubigfish View Post
    OK never seen it like that before, so I take it the other end of the flange is only half on the pipe to get it to seal.
    Did you think of wrapping the dump pipe to keep radiant heat away from your firewall??
    I see the other end has a slight flare so it all fits together, very well thought out,,,,lol
    The stock nissan exhaust has the same but on a much smaller scale
  6. #7334
    Mar 2016
    Canberra ACT
    G'day Growler, did you get this from 4x4 super centre? Looks the same as the one I just had delivered & I'm pissed because it's only 2" from the dump to the cat.
    On the site it states "full 3" system" & large diameter from the dump. Is it as you expected & how is it performing?
  7. #7335
    My 90-100 headlight globes arrived, when it cools down abit outside Ill remove my 100watt HID
    and go back to halogen globes,
    @Firetrol so yours looks nothing like Growlers,,, bummer you got stitched
  8. #7336
    Mar 2016
    Canberra ACT
    threedogs it looks exactly the same, shouldn't it be 3" from the turbo connection through to the cat?
  9. #7337
    @Growler2056 what size is your dump pipe @Firetrol is
    having troubles with his newly purchased exhaust
  10. #7338
    Mar 2016
    Canberra ACT
    @Growler2056 what size is your done pipe @Firetrol is
    Thanks threedogs, Growler commented on another post that his was the same as mine. He also had a few other issues with the mounts.
    I'm trying to decide whether to run with it anyway as it may not be an easy return.
  11. #7339
    if it looks the same as Growlers ,,,whats the issue ???
  12. #7340
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    I wired my Wholesale Automatics Torque Converter lock up switch module into the Transmission ECU harness. Not quite complete, need to finish it off and work out where I am going to mount the switch in easy reach. I just have it hanging loose at the moment as I ran out of time.
