Page 733 of 1054 FirstFirst ... 233633683723731732733734735743783833 ... LastLast
Results 7,321 to 7,330 of 10538
  1. #7321
    22 Post(s)
    Swung a spanner on the ute for the first time in what seems like years. Pulled one front shock off as it has a bent shaft, the other one has pitting and rust has started showing up, so I'll replace the shafts, change the shim stack start and doing my own shock tuning
    Only basic tools required to strip them down
    96 GQ coil/Cab
    08 G6eT
  2. The Following 4 Users Say Thank You to Ben-e-boy For This Useful Post:
    Clunk (27th February 2017), mudski (25th February 2017), threedogs (26th February 2017), Touses (27th February 2017)
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Almost finished tinting. I left the front windows to show the comparison.
    IMO and should be taken with a grain of salt.
  5. The Following 5 Users Say Thank You to Parksy For This Useful Post:
    Clunk (27th February 2017), gubigfish (26th February 2017), jack (3rd March 2017), Rossco (1st March 2017), threedogs (26th February 2017)
  6. #7323
    Aug 2014
    Perth
    10 Post(s)
    Dawes and needle fitted cheers @mudski for the call
    And nearly got this all fitted. Just gotta tighten it up in the morning
    What's with the excess exhaust tube sticking out past the flange? Did they not weld those on?
  7. #7324
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    @Parksy how hard has it been to do it yourself? Was looking at attempting it myself
    2002 GUIII Ti 4.8
    Details here
  8. #7325
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by gubigfish View Post
    Yes mate its welded, thats similar to male/female fitting
  9. #7326
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by Mike02Ti View Post
    Highly unlikely I'd have the patience for that :0
  10. #7327
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Hey growler are Hahn making exhaust lube these days ?
  11. #7328
    Jan 2013
    Nowra NSW
    5 Post(s)
    It takes a little practice but isn't that bad. I think the hardest part is cutting the tint to the correct size. I watched a lot of YouTube videos to get the technique down pat first.
  12. The Following User Says Thank You to Parksy For This Useful Post:
    Mike02Ti (27th February 2017)
  13. #7329
    Aug 2014
    Perth
    10 Post(s)
    OK never seen it like that before, so I take it the other end of the flange is only half on the pipe to get it to seal.
  14. #7330
    Did you think of wrapping the dump pipe to keep radiant heat away from your firewall??
    I see the other end has a slight flare so it all fits together, very well thought out,,,,lol
