Page 732 of 1054 FirstFirst ... 232632682722730731732733734742782832 ... LastLast
Results 7,311 to 7,320 of 10532
  1. #7311
    Makes me wonder threedogs , what is better blower or fan ?
    TBH I only used it as it was lying around, I looked at the Engel Turbo 40ltr
    and the turbo was the addition of the fan. I left the fridge running for years
    off the aux battery as I was travelling a fair bit. Now not so much.
    Take the cover[metal] off your Engel theres not much to them.
    Quote Originally Posted by PBBIZ2 View Post
    http://www.ebay.com.au/itm/152215332...%3AMEBIDX%3AIT
    This one is 30A, but you can get another for 40a, which I did. Simple to wire, just need to find somewhere to fit it - IP68, so a dunking won't hurt it. It does 'buzz though' but you can only hear that with the bonnet up.
    Would this do a similar thing ??
    http://www.ebay.com.au/itm/New-DC-Co...-/161856391189
  4. #7313
    Brought some 90/100 H4 halogen globes, not arctic blue just plain old H4 90/100
    globes. I have the light bar which Im about to fit a sep up transformer to ,,so that
    should brighten things up heaps. Think kiss is the way to go lol
  5. #7314
    195 Post(s)
    [QUOTE=threedogs;716362]Would this do a similar thing ??
    [url]http://www.ebay.com.au/itm/New
    Yes, but the max output is at the highest voltage rating, and the led's are rated at 10-30V, hence why I went for 28v as next just appeared to be 48V. it academic really as I wont be switching from 12v to 28 v to check. I did look at that one but went for higher amperage also.
  6. #7315
    195 Post(s)
    I am staying with the 70W HID's for the time being for headlights, until I resolve the GVM upgrade
  7. #7316
    my headlights are 100watt HID and have burnt some of the reflective material off.
    I dont do much night driving if any.
    On the transformer my light bar is 240watts drawing 20 amps
    Ill see which is the cheapest option to get better light what do you think
    would suit,,,thinking running the higher volts will bring the amps down by half
  8. #7317
    195 Post(s)
    TD, have a look at related read of a similar topic I raised recently re my 700w lightbar. The explanation by 'sorry forgot his tag' was really good. You can then do the 'numbers on what your current draw will be - its not a straight Ohms law determination. I ended up tong testing my current draw with a tong tester that did DC, and found I was drawing 9amp at 12V, which equated to 108W. The unit was supplied with a 40amp fuse - nothing added up. For me, I went with the 28V unit and as high an amperage rating I could get, even though it would not, in theory provide enough capacity. Either way, I think you will see a tangible difference. I am not an electrical engineer so cant comment regards what you are currently finding, as it does not seem to match what I have experienced - is you transformer voltage 12V?
    threedogs (24th February 2017)
  10. #7318
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    changed an engine mount.. the old one may or may not of fallen in two.
  11. The Following User Says Thank You to garett For This Useful Post:
    mudnut (24th February 2017)
  12. #7319
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Re tinting the patrols windows. About half way through and happy with the results. Not perfect mind you but a million times better than the condition of the old stuff.
    IMO and should be taken with a grain of salt.
  13. #7320
    Feb 2011
    Shed
    45 Post(s)
    Dawes and needle fitted cheers @mudski for the call
    And nearly got this all fitted. Just gotta tighten it up in the morning
  14. The Following 4 Users Say Thank You to growler2058 For This Useful Post:
    Clunk (27th February 2017), Hodge (25th February 2017), mudski (26th February 2017), Touses (27th February 2017)
