Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 12 Volt Kettle
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    12 Volt Kettle
    Any one used a good one?
    Sometimes a cuppa on the road is required before you reach the destination, where of course beer does the job.
    Waiting 25 mins for a cup of tea seems extreme.
    Adventurist stevemc181's Avatar
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    I use a Jetboil system, packs away easily and boils the water in a couple of minutes. You'll be waiting a long while for any of the 12volt kettles.
    They aren't cheap, but I love mine https://www.snowys.com.au/jetboil
    Patrol Guru matfew's Avatar
    Nov 2012
    Mmmm can't imagine a jet boil is easy to use while driving...
    I had a 12v kettle I got off ebay. Was just a cheap one but done the job. Only issue is it had no temp cut off so if you forgot about it you would smell burning playing after about an hour as the element melts it's easy through the side of the cup..... Haha
    Jul 2016
    Thornlands QLD
    Somtimes the trusty old thermos is hard to beat.
    Sid
  6. The Following 2 Users Say Thank You to Cyclone For This Useful Post:
    DX grunt (15th February 2017), jack (16th February 2017)
    Patrol Guru TimE's Avatar
    Canberra
    Had one, took forever to get the water past warm. Not worth the effort. Thermos is what I use.
  8. The Following User Says Thank You to TimE For This Useful Post:
    threedogs (16th February 2017)
  9. #6
    Nov 2012
    Mine took about 20 or so mins to boil. But if you plan it I didn't have an issue. Not ideal if your sitting waiting bit I used mine at work. I work out of my car a lot in remote sites so was easy to just turn it on 20mins before smoko and was done when I was ready
  10. The Following User Says Thank You to matfew For This Useful Post:
  11. #7
    I also have a jet boil. Beast of a thing. Compact. Super fast. I rate it over everything else I have. It's the only thing I have that will boil water in the snow or at altitude.
    Stop revive survive. If you need a coffee then the 5 minute stop to make one will do you the World of good. Jetboil for the win
  12. #8
    WA Wheatbelt
    23 Post(s)
    I’ve got a 12v, Waeco, cigarette lighter job. Happy with it. I haven’t secured the base yet, so I pull up before I ‘put the kettle on’. It’s another job on the ‘To do’ list. Lol.
    I don’t fill the kettle up all the way for one cup, but use the minimum amount of water possible. That way, the water boils quicker.
    My water either was very, very hot, or boiled.
    Take care out there.
    Rossco
  13. The Following User Says Thank You to DX grunt For This Useful Post:
    Bush Ranger (17th February 2017)
  14. #9
    Quote Originally Posted by Cyclone View Post
    Sid
    Yeah I agree, boil the water in the morning before leaving camp and you have hot water all day.
  15. The Following User Says Thank You to Winnie For This Useful Post:
  16. #10
    12v kettles are not the most efficient things at the best of times.
    I pulled the guts out of one and fitted in to a pot, made it water tight
    with a tight fitting lid. Filled with water and a few hot dogs it took
    20 mins to cook but like others they were put on prior to say a
    morning tea stop on the tracks.
    As for hot water I have a few Stainless steel thermos flasks for that.
