12th February 2017, 05:20 PM
#11
Radiators are pretty cheap I just replaced mine for $300.
you're talking about the top plastic tank, I think a radiator place
could "rod" your radiator and refit both top and bottom tanks.
Ring Natrad or similar and see what they say
12th February 2017 05:20 PM
12th February 2017, 07:25 PM
#12
Filled the Radiator with coolant and saw now that its drippin on the left bottom side of the bottom tank/radiator. Filled around 7 Liters and lost 2 or something like this. Unfortunatly I wasn't able to spot the leak. The next nafrad shop is 12km away and I'm not sure if I can make it up there. 300 for a new one would be okay. Where did you got it and was is with installation or do you fixed it by yourself?
12th February 2017, 08:00 PM
#13
Dribble Master
Or let TDs over heating fairies take a look at it for you ............
13th February 2017, 01:38 AM
#14
Left side, passenger side?
On the bottom of the radiator tank on the end there is a hex shape threaded plug. That's the drain plug for the radiator, make sure that it's tight.
13th February 2017, 05:52 AM
#15
No I mean left side when u stand in front of the car. So it's drivers side but will check it again when I refill it after work to drive to the shop. I think when I fill it I should be able to drove a few kilometers without overheating.
13th February 2017, 05:58 AM
#16
That side has the bottom radiator hose.
Check to see the condition of it.
13th February 2017, 04:51 PM
#17
Okay, was at natrad today and they made a very short pressure test because it started directly to come out at the radiator so I need a new one. The guy at natrad offered me a radiator for 405 (aftermarket) and around 120 for the fitting. Where did you find your one for 300? I rang a few more mechanics but they were all around 600 and more. Now I'm also worried that the one from nafrad is maybe not that good because it's the cheapest one? Do I need to choose something special or just any aftermarket?
14th February 2017, 11:52 AM
#18
Aftermarket should be fine.
14th February 2017, 01:47 PM
#19
Thiloow
I brought mine on Ebay from Bundoora radiators
'Mudski picked it up for me and Jay see fitted for me
no problems whats so ever since its been it
14th February 2017, 02:31 PM
#20
Dribble Master
Thiloow
Threedogs car is a ZD30, so not sure if the radiatior for a TB45 is bigger or not........ there are plenty on ebay for less than $300 but no idea on what the quality might be like.
The Following User Says Thank You to Clunk For This Useful Post:
threedogs (14th February 2017)
