24th December 2016, 08:47 AM
Moderator
The Following 17 Users Say Thank You to MudRunnerTD For This Useful Post:
10G (4th June 2019), Bacho86 (24th December 2016), bignev (24th December 2016), Bob (24th December 2016), BrazilianY60 (24th August 2022), Col.T (8th February 2017), Hodge (24th December 2016), Ibbo (14th June 2018), jack (24th December 2016), John43ls (6th February 2017), Mc4by (24th December 2016), my third 256 (11th February 2017), OuchOne (12th May 2022), PeeBee (6th February 2017), threedogs (26th March 2017), Touses (7th February 2017), Wine_maker (31st January 2018)
24th December 2016 08:47 AM
24th December 2016, 08:50 AM
Great Write Up . How about making it a Sticky
@mudrunner
The Following 2 Users Say Thank You to Bob For This Useful Post:
MudRunnerTD (24th December 2016), Touses (7th February 2017)
24th December 2016, 08:52 AM
Never done this my self. But this is the most detailed photo guide I've seen. Will definitely have a crack now. Thanks Dazza !
The Following User Says Thank You to Hodge For This Useful Post:
6th February 2017, 08:53 PM
Excellent step-by-step photos. I feel like I've already done it! Thanks heaps.
The Following User Says Thank You to John43ls For This Useful Post:
MudRunnerTD (8th February 2017)
8th February 2017, 05:14 PM
Good one Muddy.
Works for me. Just a minor quibble though. As I was taught how to grease wheel bearings, at the end of re-assembly, 1) tighten up to a specified max., 2) turn the wheel several times both directions to ensure all is correctly 'seated' then 3) release to zero torque and spin several times again then 4) finally tighten up to effectively finger tight.
The torsion wrench settings I think that suite the Patrol (GU and GQ are close enough) are 1) about 185 N.m.....(and this is a pretty big time twist and 4) 4N.m ...not much more than finger tight.
Roughly 60+ years have made me a creature of habit and anyway, I spent dough on a torsion wrench and I'm gonna get value out if it!!!
Cheers,
Col
The Following User Says Thank You to Col.T For This Useful Post:
8th February 2017, 05:19 PM
Nice write up. Playing with fire with one of those screws though, not much for the screw driver to grab :P
The Following User Says Thank You to Throbbinhood For This Useful Post:
8th February 2017, 08:56 PM
Moderator
Throbbinhood
Lol! Yes your right they have seen better days. I have undone them a few time now but from memory I did that damage the first time I had to undo them 150,000 kms ago.
![Cool](images/smilies/cool.png)
Check out my Toy -->
Rogue Dung Beetle
8th February 2017, 09:02 PM
#8
Moderator
Col.T
Good one Muddy.
Cheers,
Col
Yeah all your torque measurements are correct although good luck with the 185nm! It's bloody tight and I wrecked one of those wrench sockets trying to achieve it.
This write up was more aimed and a routine maintenance when servicing. Check for slop, if loose you can nip them up in 5 minutes without worrying about the torque settings.
If you have just replaced the bearings then it's a much bigger task and as you say you need to apply the routine you have clearly outlined so thanks for the add mate. Winner.
I have found Patrol front wheel bearings have a tendancy to become a little sloppy and need a nip up a couple of times a year. An inspection and repacking is probably in order next time for sure.
Rogue Dung Beetle
8th February 2017, 09:03 PM
#9
First time I did the GQ I removed the wheel , where were you ?
The Following User Says Thank You to GQtdauto For This Useful Post:
11th February 2017, 08:12 AM
#10
Just been out and checked mine and were a little sloppy so 10 minutes later all fixed thanks for the write up
OH LEATHER IS NICE
![](image.php?s=55d23eeb2e586309783ebdd6c7fb0a2c&u=256&type=sigpic&dateline=1352567496)
The Following 2 Users Say Thank You to my third 256 For This Useful Post:
BrazilianY60 (24th August 2022), MudRunnerTD (11th February 2017)
