Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: How have you secured your slip off pod to your tray ,.
    475 Post(s)
    Another wacky drawing below for easy left and right alignment via opposing offset angle iron steel when loading the camper on your own.
    And just back up against a tree to shove it forward more if needed, then bolt her down :-)
    dads tractor (31st January 2017)
    Patrol Guru
    May 2011
    mackay former alice boy
    MB now we are getting to the same wave length ,I knew there was someone that would see the drama and have a solution ,WELL DONE .
  5. The Following User Says Thank You to dads tractor For This Useful Post:
    MB (1st February 2017)
  6. #13
    475 Post(s)
    But wait, there's more. For only $99.95 + PH you will receive not one but two copies of last nights blueprints :-)
  7. The Following User Says Thank You to MB For This Useful Post:
    Touses (1st February 2017)
  8. #14
    Patrol Guru
    May 2011
    Noooooooooooooooooooooooooooo not him please haha
  9. The Following User Says Thank You to dads tractor For This Useful Post:
  10. #15
    @MB loving the rattle gun, which ever way you decide I'd be using some conveyor
    belting to insulate it so you dont have steel on steel.
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #16
    475 Post(s)
    Impact driver/Rattle gun was @Old Wal 's idea above TD, I just captured it artistically :-)
    Conveyor belt rubber is great but can be a bit hard to slide over especially if on your own. I'm a big fan of HDPE & LLDPE as was pictured in my scribble. Very hard wearing, especially HDPE and both are slippery as for hip & shoulder tackle alignment.
    http://www.dotmar.com.au/hdpe.html
    Haven't purchased off Dotmar before but they have a great range of extruded profiles on their web too.
    http://www.dotmar.com.au/extruded-pl...-profiles.html
    Something like R125 profile to cap angle iron could work hopefully.
  13. #17
    Aug 2014
    Perth
    10 Post(s)
    Quote Originally Posted by dads tractor View Post
    Thanks mate dont want to bolt through floor so was wondering about a system to under the tray . Keep in mind this will not be on nice concrete drive ways just as a added challenge aye .
    The ideal would be camlocks like on trucks but too big .
    Why not carry around 4 flat bits of timber to sit the Lift off legs on, set the height so you can reverse under it and your done surely.
  14. #18
    Jul 2012
    North East Victoria
    4 Post(s)
    OK thanks for everyone's input ; why dont I want to use bolts through the tray because when I unload at no cement to jack on camp with no one in sight it's a bit hard to secure the pod back on and move it to get bolts back in .
    Probably a bit hard to see in my photos but on both the front and rear pads that I bolt through are designed to fit snug against the inside of the gunnel on my tray - makes locating my camper in relation to the bolt holes in tray easier. I don't have any dramas on uneven ground - I don't unload on a cement pad at home either.
    Remember that a high IQ doesn't make up for a lack of common sense.
    Learn from the mistakes of others - you won't live long enough to make them all yourself !
  15. The Following 2 Users Say Thank You to Old Wal For This Useful Post:
    dads tractor (1st February 2017), MB (1st February 2017)
