Page 191 of 220 FirstFirst ... 91141181189190191192193201 ... LastLast
Results 1,901 to 1,910 of 2192
Thread: AB's new GQ is finally here
  1. #1901
    Still what looks like to me grease coming out of the ball joint after a clean and drive.
    As mentioned above, over greased so do I need to do anything or just enjoy the greeezy love?
    Change the axel seal and be done with it. If you havent already get yourself a oil seal installation tool, about $30 on fleabay, and a good oil seal pick.
    If have both you can use if you dont have them.
    Just drove a total of 10 hours with off-roading and long steep climbs and hot weather.
    Runs a lot cooler than my old one. Temps are perfect!
    It just pulls up hills like a dream!
    Even our worst section heading up a long steep 4wd track very rutted for at least 10minutes solid powering up in 2nd low at 2200 only got to 95 degrees and EGT was 400.
    Had similar temps as above on other hills when lagging around 1900rpm so if you keep it spooling at 2200 to 3000 it loves it!
    Engine seems great, turbo is sensational in the high country, many times I hit big hills not concentrating in 2nd and should've been in first and the turbo spools up to 2200 with no lagging and next minute your charging up the hill.
    Absolutely blew marks Mrs GU ht18 away on the black stuff windy steep hills with Marks car to the boards and mine 1/3 pedal.
    Its great having power on tap hey! My car fully loaded at 3.18t and dragging a 1.7t camper i rarely had to reach for 4th on hills. But i only did actually because last time i did this same trip i cooked the gear oil because the 5th gear loving and couldnt change gears when coming into towns. So i now drop it back to 4th and ease off a little.
    The only slight issue is i have to clean the back of the car and front of the camper from black soot. Lol.
    AB (10th January 2017)
  5. #1903
    583 Post(s)
    Change the axel seal and be done with it. If you havent already get yourself a oil seal installation tool, about $30 on fleabay, and a good oil seal pick. If have both you can use if you dont have them. Sent from my GT-N7105T using Tapatalk
    It was leaking after a little front wheel airtime on Ellis track, seal was replaced and it started leaking again a month later.
    I'll get the seal done again and fingers crossed!
  6. #1904
    Yeah i found them to be a pain. I reckon ive changed the rhs three times.before if finally stopped. Now the lhs has decided to start. Not a lot, probably the same as yours, bit enough to annoy me as i know its not right.
  7. #1905
    43 Post(s)
    Soo..
    Whens the party?
    Ive got 5 days off over Australia day
    Sent from my SM-G800Y using Tapatalk
    .......... TPC's Avatar
    63 Post(s)
    Soo..
    Whens the party?
    What he said.
  9. The Following User Says Thank You to TPC For This Useful Post:
    BigRAWesty (11th January 2017)
  10. #1907
    583 Post(s)
    Sorry folks it's been hectic lately.
    Leah's been in hospital for the last 7 days and I'm working and looking after kiddies.
    Finances are crucified too unfortunately to host anything like this.
    Give me some time and hopefully things can get back in order.
    2017 has been a shitful start for us unfortunately!
  11. The Following 8 Users Say Thank You to AB For This Useful Post:
    Bacho86 (12th January 2017), BigRAWesty (11th January 2017), Chappy (30th January 2017), jack (11th January 2017), MudRunnerTD (11th January 2017), mudski (11th January 2017), Stropp (12th January 2017), TPC (11th January 2017)
  12. #1908
    63 Post(s)
    Didn't mean to put any stress on you, we were just after an excuse to get together.
    I hope everything is ok with Leah & hopefully things will improve for you.
  13. The Following 4 Users Say Thank You to TPC For This Useful Post:
    AB (11th January 2017), BigRAWesty (11th January 2017), Rossco (11th January 2017), Stropp (12th January 2017)
  14. #1909
    583 Post(s)
    Didn't mean to put any stress on you, we were just after an excuse to get together. I hope everything is ok with Leah & hopefully things will improve for you.
    I'm keen to do this mate as a thank you and well...Another party really
    Just a horrible start for us mate.
  15. The Following 5 Users Say Thank You to AB For This Useful Post:
    BigRAWesty (11th January 2017), Plasnart (11th January 2017), Stropp (12th January 2017), TPC (11th January 2017), Winnie (11th January 2017)
  16. #1910
    Aug 2014
    Perth
    10 Post(s)
    Get yourselves healthy a party can wait
  17. The Following 4 Users Say Thank You to gubigfish For This Useful Post:
    AB (11th January 2017), BigRAWesty (11th January 2017), PeeBee (11th January 2017), Stropp (12th January 2017)
