3rd January 2017, 02:01 PM
main bearing size
Hey guys,
new to this,,
I got a 1998 gu tb45e aftermarket turbo setup motor has about 300k running 7lbs boost,, looking to rebuild motor,
Can anyone give me some advice as looking to run "h beam conrods" for td42 as I think are same length... what I need to know is if the same size main bearings for both tb45 and td42, the stroke are the same at 96mm n obesely the bore is different as the td42 is 96mm dia and tb45 bore is 99.5mm... any info greatly appreciated!!
3rd January 2017 02:01 PM
3rd January 2017, 04:37 PM
Hello and welcome to the forum jump in anytime you like and enjoy,
This is the intros,,, you might get a better response if you post your question in
the mechanical section, as not many read the intros
3rd January 2017, 06:20 PM
Welcome to the forum mate
3rd January 2017, 07:26 PM
Smart like tractor
crumpy71
Hey guys,
new to this,,
From what I have found the part numbers for tb and td are different
http://mail.precisionintl.com/Part.a...=5764&EID=3568
http://mail.precisionintl.com/Part.a...=5770&EID=3579
Edit
This is tb45, which is the same as a tb42
http://mail.precisionintl.com/Part.a...=5764&EID=3569
96 GQ coil/Cab
08 G6eT
![](image.php?u=1281&type=sigpic&dateline=1483248064)
threedogs (4th January 2017)
10th January 2017, 04:58 PM
